Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
I Need Help
Old Mar 2, 2007 | 10:37 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Default I Need Help
http://forums.corvetteforum.com/show...post1559205137
Old Mar 2, 2007 | 11:12 PM
_twisted_'s Avatar
_twisted_
i SEE YOU AND dAVE SPOKE IN THE OTHER THREAD
Old Mar 3, 2007 | 09:58 AM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
Does GM peroformance make a create motor for this ?
What about some of them race prep motors advertised in National Dragster?
Old Mar 3, 2007 | 11:03 AM
C3AV's Avatar
C3AV
I have a 632 ready to go..........
Old Mar 3, 2007 | 11:16 AM
Vic'89's Avatar
Vic'89
John - What went in your motor ?
Vic
Old Mar 3, 2007 | 07:15 PM
RichS's Avatar
RichS
Vic
Vic,
At the top end the bottom end blew out taking a 6" square chunk out of the block that was laying on the crossmember. I would like to see pics of it once removed.
Old Mar 4, 2007 | 05:41 PM
Turbo Bob's Avatar
Turbo Bob
Corvette Challenge Champ-01
Dragster Challenge Champ-06
Hey Mack,
Check out Golenengineservice.com Excellent rep. with LT-1's
Old Mar 6, 2007 | 10:22 PM
mackeyred96
I’m still debating what to do
Old Mar 6, 2007 | 10:32 PM
jpee's Avatar
jpee
John the girl who bought my old 89 tan Honda still has it... the AC is not working and it has a little more body rot.. but it runs strong (145,000 miles on it..
I bet it will still run under 20's and the best part is it will be nice and safe for a man of your Maturity
Old Mar 6, 2007 | 10:43 PM
mackeyred96
Old Mar 7, 2007 | 07:41 AM
BlackC6LS3's Avatar
BlackC6LS3
Originally Posted by Turbo Bob
Hey Mack,
That's what I was offering for sale
Old Mar 7, 2007 | 08:39 AM
Turbo Bob's Avatar
Turbo Bob
You need to decide, carb or fuel injection. Then go from there. I know you want to run Super Street so take that into consideration also.
Old Mar 7, 2007 | 08:57 AM
1996LT1's Avatar
1996LT1
With SuperStreet in mind carb...or at least a conventional type intake/throttle body. Theres no readily available throttle stop for the LT1/L98 configuration.
Edit: I cant believe I'm up this early
Old Mar 7, 2007 | 09:16 AM
Turbo Bob's Avatar
Turbo Bob
Go back to sleep Joe
Old Mar 7, 2007 | 09:21 AM
Eric Fischer's Avatar
Eric Fischer
John, what about a carbed LS2 motor? As we know the LSX motors can easily make tons of power yet still have great driveability. Not to mention they are lightweight.
Eric
Old Mar 7, 2007 | 12:03 PM
ralph's Avatar
ralph
John, Blackrose's engine is what's left of Chris's 396. Those are some real nice AFR LT1 heads on that engine. However, if you're really planning to run super street you'll want a bigger bullet IMO. A big block is the way to go, if you're willing to do what's necessary to make it fit. Otherwise, i'd recommend a convention big inch small block with 18-15 deg heads if you can afford it. If not, you might want to use Chris's car as a blueprint. In either case......plan on a high rise hood along with everything else.
To I Need Help
