Simple answer is too many passes under 11.50 without a rollcage. Stock C6Z on stock tires. Had been given 2-3 passes on prior visits before being told to park it. Was finally banned at a private rental after 3d pass under the limit.
NHRA/IHRA needs to get with the times. Stock C6Zz can run under the limit on the stock tires.
Good folks run Cecil but they do stick to the rules and you can't blame them for that. Good racing surface, return road a little rough, staging lanes are downhill so its an easy roll up to the box - paved pit area can get tight with a big racing crowd. I've heard some refer to the dragway as "Down Hill Cecil" because a lot of guys have posted some of their best times and MPH. Good racing group, friendly and esay to talk with during the day. Good quality competition - track does a super job with Vintage Thunder each year. Have fun and enjoy you should get all the Test n' Tune you want.
