Tubes for CCW's
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
I'd ask that you to rethink that, I feel tubes can be very dangerous.
I run the same tire, w/tubes and screwed as well.. I was under the same impression when I got mine.. I don't think you need the Tubes. It just adds weight and the screws won't go all the way through.. and if you think they will just add a small washer ..
Plus you have to drill out the hole for the valve stem..
I would have to agree with John on this...
Ernie
Ernie
Cruise-In IV Veteran
As I understand it, you drill holes around the lip of your rims and insert screws into the holes....these screws grab the tire inside and prevent it from moving on the rim at launch...this, in turn, allows the tire to wrinkle or fold at launch resulting in a better hook and short time...
I put screws in my CCW's due the the tires spinning on the rim up to 1" each pass. Plus after having a friend suddenly lose all tire pressure in one of his tires after getting off his trailer(screwed and no tube), I decided to go with tubes.
[QUOTE=Face;1560836969]Why is that>?
QUOTE]
Can you please tell me which tube maker, part #, price, retailer you got them from?
Thanks,
QUOTE]
Thanks,
If you are going with the tubes make sure you put a ton of baby powder on them to avoid them sticking to the rim and tearing. You will find the tube to fit a little tight on the 16 inch rim. They work but having tried it both ways I prefer no tubes.
Thanks,
! From what I have been told by MT and John of CCW, If the tire moves on the rim, you will sheer the tube valve stem. That is why you MUST screw the tire to the wheel. Now, as far as CCW wheels for C5, Viper and Supra, The offset does not alow for proper placement of the tubed valve stem. According to John, a tube could be used but it would require 20+ Lbs. and still not be uniform within the tire. Also, Paul Major mentions using powder so the tube does not adhere.
