Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Staging light on off interval question
Old Jul 13, 2007 | 07:17 PM
cc42's Avatar
cc42
Default Staging light on off interval question
I know the delay between the third amber and the green light is .500, but my question is: Is the third amber on for .025 and then off for .025 and then the green comes on? For example, if you wanted to leave when the second amber goes out, is that .750 before the green comes on?
Old Jul 13, 2007 | 08:22 PM
jonszr1's Avatar
jonszr1
Alot of guys will put 1sec in their delay box if they want to leave on the second light. i sure wish they would just go back to only using the pro tree . one yellow and go. i could time that one
Old Jul 17, 2007 | 11:52 PM
kazman's Avatar
kazman
Thinking outside the box? I deep stage and if I jump on a flash instead of "waiting" for the 3rd amber I'm -.025 to -.035 (very red). My shallow shaging racing buddy decided this week to leave when the second yellow went out. His reaction time droped by .025 to .035. Put his RT's into the .00x to .01x range. I'm guessing that's what your asking.
I believe most using a delay box go off the first bulb not the second. Gives a "true" reaction as you don't look at any lights comming down.
Old Jul 18, 2007 | 10:51 AM
blackmajik's Avatar
blackmajik
Default delay box
we set the delay box between .950 to 1.000 and leave on the first amber which will usually put a r/t in the low teens(.010 or .020)unless i fall asleep,and i seem to do that when i run allthrottle no bottle
Old Jul 18, 2007 | 12:35 PM
Glensgages's Avatar
Glensgages
I read about this on another bracket-racing Forum, and it really made me think twice.....
the subject in-question was how to foot-brake an EXTREMELY slow-leaving car, a car so-slow that deep-staging and leaning on the converter as-hard-as possible stillresulted in very-poor RTs
(I have a Cross-Fire in an '82 Corvette that runs 2.3-2.4 second 60' times, even-with 3.73s gears, so I read with interest ):
a very-good bracket racer said he'd had sucha car once, and here is how he staged & launched the car.....
He staged (both-bulbs lit ) with his RIGHT-foot on the brake-pedal, and with the motor at-idle, he simply 'swapped-pedals' at the flash of the SECOND-bulb, mashing the gas with the same foot:
since he had practiced this method for a few weeks, and on his practice-tree, he could routinely get .02-.04 RT from a car that would go no-quicker than .08-.10 deep-staged.
I have since given-up on the '82 until it is more to my-liking, but somebody who has the desire & discipline could use this method to his advantage.
Old Jul 18, 2007 | 03:52 PM
stampede3's Avatar
stampede3
Me too, I'm usually around .1020 for night and .980 in the daylight with consistant .020s
To the OP each light is .500 apart, all I can say is it is on for most or all of that and the next lights up *** soon as the previous goes out.
When I foot brake a street car I leave on the last yellow.
Old Jul 18, 2007 | 05:20 PM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
Hmmmmm....I had heard about "one footin" it" but forgot about it...this may be worth a try for me if all else fails...hmmmmm...
I tried another trick but could not get it to work...this one is where you hold your foot about an inch or so above the gas pedal and drop the hammer from there....this helps if your spot is a hair too early...
Old Jul 18, 2007 | 05:30 PM
Glensgages's Avatar
Glensgages
I had seen the story about the 'one-foot/two-step' dance-method, and passed it along to your half-brother Ignatowski:
maybe he passed it along to you?
Trying to 'shim' your foot off the skinny-pedal is still a tricky-proposition, and never worked for me:
I think the guy who mastered that technique realized that in the time it took for his Right-foot to go from applying the brake-pedal to mashing the gas was about the proper delay to leave on the 2nd bulb, but if you have that hesitation fixed, I doubt you'll need that-much lead-time
Old Jul 19, 2007 | 03:08 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
I fixed the guy's with the delay boxes last month,I set .007 into the tree and they are still tring to figure out what happened.
21 red lights in the first round.
This month I am going to set up the tree for a 7 second count on the pre stage light.
To Staging light on off interval question
