What a horrible day to be racing but it still does beat being at work!
Tried to catch you after first round but you'd already split, what happened? Did you make it back to Etown in time?
I was really happy after first round, went .000 on the Pro Tree!
Never been that close before, ran 10.05 on the brakes. Second round I didn't have the shifter all the way in 1st and the trans brake wouldn't set so when I went up on the two-step I pushed thru the tree before it was activated and was red, end of day.
See ya' at the next race,
Dave
Dave,
Way to go! Sounds like you were in "The Zone". How is the stocker going? My engine goes to the dyno on Tuesday. The Cecil County points race is getting closer. Later
Put a new ATI stocker special converter in it + new MSD dist. went to the track, first run blew the tires off at 27 PSI ! Decided to run it on thru so I could check the R's at the stripe, just past 1000' hit a downpour Eased off the throttle and coasted/slid to the last turnoff. Whew I'll try again this weekend, let me know when/where you're going to test it at.
