Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
M6/MN12 Diff Breakage
Old Aug 3, 2007 | 10:40 AM
Tech's Avatar
Tech
Default M6/MN12 Diff Breakage
What kind of tires can we get away with? What 60fts? I've been a long time owner of f-cars and know the factory rear ends couldn't hold a slick with a manual tranny (leaving hard). How about the Vettes?
Old Aug 3, 2007 | 05:40 PM
Ranger's Avatar
Ranger
It depends on the power-level, specific mods, and "how hard is hard."
I launched a stock C5Z on MT ET Street Radials at up to 5200 rpm for passes #300-#350 . About 250 of the first 300 passes were on BFG DRs launching at 3600-4200 rpm. Plus 50 passes on stock tires. Never broke anything.
But if you
(1) add more than 30 or so rwhp
(2) add a strong-clamping aftermarket clutch and/or
(3) launch at >5400 rpm
the breakage risk goes up significantly on both DRs and MT bias-ply.
So, at that point hardening of the rear becomes prudent.
I should add that driver error during the burnout or launch can break an axle or differential even at stock power levels no matter the tire. run.
Ranger
Old Aug 3, 2007 | 06:50 PM
robz's Avatar
robz
But if you
Ranger
I've run mt et streets and launched hard for a few hundred passes.
I've broken the rear once and output shafts 2x. The tranny/rears are quite strong imo. Most guys go with hardened left output shaft. I wouldn't change anything until it breaks. The stock trannys have been proven to hold up to alot of abuse. Don't beef it up unless you have a problem. Many 60' times in the low 1.4x's with 3.90's and 4.10's
Old Aug 3, 2007 | 07:58 PM
Tech's Avatar
Tech
I'd definitely consider 1.6x 60fts 'leaving hard' for a mostly stock car. I'd be happy with high 1.7xs.
I've read there were differences between the 01 and 02-04 Z06 clutches. I don't know *what* the differences are but I presume the 01 clutch doesn't hold up to the abuse as well as the newer clutches?
Old Aug 3, 2007 | 08:22 PM
Ranger's Avatar
Ranger
^^^ Tech, I had 150 passes on a stock 2001 too. On BFG DRs I cut some 1.70 60'. Never broke anything on DRs or stock tires
The clamping force of the Z06 clutch was given 7% more clamping force when the HP was increased from 385 to 405 in 2002.
Ranger
Old Aug 6, 2007 | 04:57 PM
chiefDave's Avatar
chiefDave
St. Jude Donor '05-'06
It is all about seat time IMO. I never got 1.7s untill I got 40 passes, and then went to MT ET street DRs. heated up, and a 4-5k launch on the stock clutch got me 1.5s. The clutch was tired so we upgraded it then, and did both shafts and a DTE brace.
Now running bias plys and hard launches, the shorts are mid 1.4s to 1.5s, but I have broke 2 3.90s. Like above, dead hook or wheel hop can be very bad. It will show the weakest link.
Good luck man!
Dave
To M6/MN12 Diff Breakage
