Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Help .490 RT
Old Aug 11, 2007 | 02:50 PM
the need for speed's Avatar
the need for speed
Default Help .490 RT
I leave on the last yellow and have been cutting a lot of .490 lite is there anything I can do to the car to help this out if I leave a little latter I am cutting .650 lite not good I dont want to mess up my 60' times 1.35. The front end is not coming up out of the lite.Any suggestions would be appreciated thanks:
Old Aug 11, 2007 | 04:54 PM
_twisted_'s Avatar
_twisted_
leave on the second yellow
Old Aug 11, 2007 | 06:01 PM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
First I have to presume your track is measuring .500 as perfect, most tracks have gone to .000.
I presume you are as shallow as can be? That 1.35 short time means your car is leaving pretty fast. Maybe if it did lift a little it would slow it down? Maybe a taller front tire or less pressure on the front tire?
Old Aug 11, 2007 | 06:02 PM
REDGAR's Avatar
REDGAR
CI VI Drag Champ!
What kind of ET you running with that 1.35
Old Aug 11, 2007 | 06:46 PM
Glensgages's Avatar
Glensgages
A 3rd suggestion is simply lowering your launch RPM 300-500..... the fraction-of-time it'll take for the car to move w/ the lower launch RPM (a bit-more 'slack' in the driveline ) may result in slowing-down the initial move of the car, and lights in the .51-.52 range, if this is your goal.
Old Aug 12, 2007 | 04:53 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
I just add a few pounds of air to my front tires and that will usually add a .10.Lowering the tire presure will result in the car rocking back harder and you will get a quicker light.
Rock the light ,I do it all the time.With the new computers if you rock out of the light it shouldn't red light you .The old computers will red lite you if you rock out of the lights.We have a new computer at the track and that is the way it is set up.I set it up
Old Aug 12, 2007 | 07:45 AM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
This is interesting...I always heard exactly the opposite of this...add front tire pressure for a quicker light...
Old Aug 12, 2007 | 12:06 PM
the need for speed
Thanks all.Yes .500 lite is perfect.iI am running 10.1 best time 9.97 at 131mph.I will try rocking on the bottom bulb see if that helps.
To Help .490 RT
