Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Holley 750 help
Old Oct 11, 2007 | 11:57 PM
Racer-rt's Avatar
Racer-rt
Default Holley 750 help
I have 2 750's on a tunnel ram on my Chev 350 in a Rat Rod 49 Ford F3. My trouble is that on the front carb gas drizzles from the venturi at idle and causes a real flooding problem. I installed a gauge and regulator and set the pressure at 4 1/2 lbs. New floats and needle and seats didn't solve it either. By the way I.m using the primaries only, the secondaries are disconnected on both carbs. Stock short block with 1.94 400 SB heads, 480-480,292-292 hydraulic cam.
I seem to remember being told by Baker Carburetors to drill a .100 hole in each primary throttle plate but I can't remember what that fix was for.
Anyone sharp on thes that can advise me, I really appreciate the help.
Rich
Old Oct 12, 2007 | 05:42 AM
98NYFINESTVETTE's Avatar
98NYFINESTVETTE
From: 10.70 @ 124mph, Stock Bottom End @ 3620lbs, ECS Racing Team Member. The 1st NMCA LSX Index Rumble World Champion. 2011,12,13 Champion
Have you check the float level? There are two screws on the right side of the carb. Remove the screws while the enging is running, You want the fuel to JUST trickle out at idle. If the fuel is flowing out at a high rate you need to lower the float. The tools to lower the float would be a 5/8 wrench and a large screw driver. Loosen the 5/8 nut and the turn the screw clockwise to lower the float level.
Old Oct 12, 2007 | 08:22 AM
Racer-rt's Avatar
Racer-rt
Thanks for the advice, but that is basic Holley adjustment. I guess I forgot to mention that the float levels are set. I have covered all of the simple stuff and am looking for an answer to what is to me a "freak problem"
I found the problem today, the vent tubes were clogged solid with what looked like beehive dirt. Anyway I cleaned them out thoroughly and it's working properly.
Old Oct 13, 2007 | 02:50 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
You can also get dribble when the 2nd dary throttle plate is not sinked with the primary throttle plate.The little screw in the throttle plate that is upside down and you can only adjust it if you remove the carb or buy the holley kit so you can set up the secondaries like a 4500 carb.
To Holley 750 help
