So if on were to have a 427ci in their '99 FRC, that would be considered a "stock cubed motor" since the C6 Z06 has the same?
Let me try...
There are two lists that are confusing on LS1TECH.
1. Fastest NA LS any C.I. - That is the fastest n/a with any cubic inch LS engine (LS1, LS2, LS6, LS7, etc)
2. Fastest N/A Stock CI, H/C - That is the fastest n/s with the engine cubic inches that came from the factory. C5Z has to be LS6 (346), C5 has to be LS1 (346), C6 has to be LS2 (366) and C6Z has to be LS7 (427).
If I am correct, YO-EL's run needs to be in the first one above; Rob's in the second one.
