Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Heed help, pistons problem
Old Jan 7, 2008 | 06:26 PM
divette's Avatar
divette
Default Heed help, pistons problem
Hi. I used Wiseco pro-tru pistons c 200 shot, CR 10.5, a bottom of the piston similar on a hole, the whole only 1 and 2 cylinder. What pistons to me to establish for a new season?
Old Jan 8, 2008 | 03:53 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
Huh ?
Old Jan 8, 2008 | 05:34 AM
divette's Avatar
divette
Advice is necessary to me: what pistons the most reliable for 383cid, rod6.0, 700hp w/200shot, CR 10-11.
Old Jan 8, 2008 | 08:56 PM
REDC4CORVETTE
Wiesco 14.8-1 pistons are what I am using with a 300 shot.
I also use in my 355 lt1 diamond pistons with ceramic coating
Old Jan 9, 2008 | 01:55 PM
divette's Avatar
divette
Thanks, but high compression. Probably I shall buy JE NITROUS SERIES DOME 232509 or Probe 13719, That tell?
Old Jan 9, 2008 | 02:10 PM
hookedup's Avatar
hookedup
I think the ProTru pistons you were using are only rated to 400-450hp and NO nitrous!
Old Jan 9, 2008 | 02:55 PM
divette's Avatar
divette
What gasket can be used?
Old Jan 9, 2008 | 06:42 PM
REDC4CORVETTE
I use Cometic Multi Layered Steel Head Gaskets .030.Mine is a stroker motor with tooled wrist pins and the block is clearenced for the crank.
I also use the H bearings coated.The pistons in the pic aren't for a real race motor.You never want sharp edges on a piston,everything needs to be smooth.
Old Jan 9, 2008 | 08:51 PM
eddie the kid's Avatar
eddie the kid
r u using a plate nitrous system or a fogger setup
Old Jan 10, 2008 | 01:25 AM
REDC4CORVETTE
NOS plate system ,with a NOS progressive timer.
The cam lift is a 698 .I use all Aeromotive regulators and fuel pump,#10an lines down to a #4 to the NOS plate and #6an to the carb,a 1050 cfm 4500 holley .I tried the Barry Grant 1095 dominator but the carb's Barry Grant makes are junk.
Old Jan 10, 2008 | 01:02 PM
divette's Avatar
divette
Originally Posted by REDC4CORVETTE
IThe pistons in the pic aren't for a real race motor.You never want sharp edges on a piston,everything needs to be smooth.
More in detail. Please. I use too coating bearing. At me a problem with spark plug, I used NGK TR55, but they quickly burn down.
http://forums.corvetteforum.com/show....php?t=1715399 my street car.
To Heed help, pistons problem
