Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
First Day - First Problem
Old Mar 2, 2008 | 05:44 PM
ARCH's Avatar
ARCH
Default First Day - First Problem
Did'nt even get one run in before we ran into problems. Did my burnout in second gear, put it into first to roll up to the line and it did'nt respond. Thought maybe I was stuck between gears. Had to back out and drive down the return lane. Turns out my drivers side wheel did'nt turn during burnout. Figure problem is either with clutch or rear end, and after preliminary inspection it appears to be rearend. Had to limp home barely able to go 35 mph.
Also turns out I have an oil leak from the front timing chain seal.
Time to open the checkbook! Will miss next weeks race at ATCO, hope to make first Corvette Challenge.
Old Mar 2, 2008 | 05:49 PM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
Sorry to hear that Arch. Hopefully you can make the first points race
Old Mar 2, 2008 | 06:27 PM
4DRUSH's Avatar
4DRUSH
We should have someone at the water box spotting for such a thing
Old Mar 2, 2008 | 07:06 PM
ARCH's Avatar
ARCH
Well, I guess I can switch to those 4:11s my dad has been pushing for, for some time. Just so frustrating, as I have been counting down the days to get out there and race, and to test some of the changes we have made.
Old Mar 2, 2008 | 08:06 PM
Eric Fischer's Avatar
Eric Fischer
It was a loooooonnnng day! Lots of oil downs, and one driver went into the sand and into the safety net (in a late model stock Caddy no less ). And being that the track surface was brand new, there was no rubber on it and it was like a skating rink. Towards the end of the day though the track started to hook.
Old Mar 3, 2008 | 07:35 AM
ARCH's Avatar
ARCH
Well at least I did'nt go head first into the wall on my burnout like the guy in front of me. Eric, how many runs did you get?
Old Mar 3, 2008 | 08:53 AM
Eric Fischer
Oh yeah, I forgot about that guy!
I got 4 runs in. The last run was at 4:30pm.
To First Day - First Problem
