Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Torque Mangement
Old Mar 8, 2008 | 10:04 AM
fasz06's Avatar
fasz06
Default Torque Mangement
With stock tune how do people get (1.6)60' times with TM in its stock computer tune? Is a car STOCK if the computer is tweeked and no other changes? How much ET improvement with only good tune?
Old Mar 8, 2008 | 10:39 AM
mowton's Avatar
mowton
Thats an interesting question, and one I have been researching. I was expereincing a bog during launch in my C5 and everyone kept telling me I just didin't know how to drive a standard My tune was developed on a Z06 STock Tune.
Turns out, the z06 actually has a more agressive Torque Management scheme than the C5. As I scan and tweak with HPTuner, I have found 2 area's which you should look at. One is the TPS vs MAP vs Torque table, and more interesting is the Injector Hop disable table. This table actually shots off injectors depending on the severity (modes 1-8) of hop (haven't figured out the modes, but I understand Torque plays into it) will actually shut off injectors (255 vs 119) to reduce power.
Now, if I am not mistaken, even turning off the traction control on the Z06 doesn't disable that function. I do know that by turning off the Traction control, I did get rid of the TP closing briefly as the acceleration ramped up in my launch. Not sure about the Injector scenario though.
Maybe someone with more experience could chime in on this subject, because I am still not sure of all the facts, or even if it is an issue......enquiring minds want to know
Ed
Old Mar 9, 2008 | 07:19 PM
Dr.Ron's Avatar
Dr.Ron
From: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
Question #1) Requires ALOT of finesse & practice on your technique & good track prep.
Question #2) Tune only car does not equal stock anymore.
Question #3) Improvement in ET is based on the driver's experience & abilities mainly....
TM is there to help prevent you from breaking drivetrain parts. It also helps reduce wheelspin. Fot the C6Z, at first TM was thought to hurt times, but after much research & logging, member Dgdoc has shown it to HELP reduce ET...
Ron
Old Mar 15, 2008 | 08:10 AM
johnnythewall's Avatar
johnnythewall
Default watch it
I had a friend who took his car in an the tuner took off all his TM and he trash his tranmission $2500.00 later his back up in running , the PC puts that TM on there to protect your car your rear end and stock transmission can only take so much time, I say work on your RT and make sure you have good tires and your racing on a nicely prep track.
To Torque Mangement
