Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Suspension Setup
Old Mar 19, 2008 | 10:47 PM
Higgs Boson's Avatar
Higgs Boson
Default Suspension Setup
How would you set up Pfadt coilovers (one way shocks, spring rate, ride height) for an 01 Z06 with a 408? I run NHRA and IHRA Super Stock but this is a very different suspension setup than I run (4 link).
I am thinking:
Front - spring as soft as I can get it; shocks loose
Rear - medium firm; shocks in the middle
Correct or correction?
Should I set ride height up even front to rear? I realize the car isn't going to launch like a drag car but I would like to get closer to "decent" weight transfer but to mainly remove unloading of the rear tires on launch. I am planning on going mid to high 9s. Thanks.
Old Mar 19, 2008 | 11:19 PM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
not sure of all the setting on the pfadt system though I do know I emailed them about drag setup and they said something like not this stuff.
If you shocks are single adjustable, I would not start all the way loose. Try a quarter, so if you have 10 setting try 2 or 3 from softest.
rear sound about right
Old Mar 19, 2008 | 11:26 PM
Higgs Boson
They have 16 settings so I will start at 4 then....
To Suspension Setup
