Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Drag Pack Question
Old Mar 21, 2008 | 01:28 PM
easyvette's Avatar
easyvette
Default Drag Pack Question
I went to have my drag wheels (bias) balanced. The front wheels needed very little weight to balance them. The back wheels they had to put a double row of weights on in one place.
They asked why I wanted the Mickey Thompson ET Streets balanced on the rear. Is it common not to balance a rear tire like an ET Street (BIAS)...
My concern is from the location of the weights I think it is possible they(weights) may conflict with my A-arm suspension and may have to take a couple off...
Thanks I really know nothing about drag wheel setups except for what they cost...
Old Mar 21, 2008 | 02:59 PM
nickolbag's Avatar
nickolbag
I didn't have mine balanced. You do not need to balance them.
Old Mar 21, 2008 | 03:54 PM
easyvette's Avatar
easyvette
Mine are Bogarts does it make any kind of a difference. I drive on the street to the track. Am I going to feel any kind of a vibration?
Old Mar 21, 2008 | 04:04 PM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
Typically rears are not balanced cause they fall off quickly, usually a burnout or two.
Old Mar 21, 2008 | 05:22 PM
Paul_Z06's Avatar
Paul_Z06
I always had my tires measured and balanced on a bubble balancer. Putting duct tape over the stick-on weights will prevent them falling off.
Old Mar 21, 2008 | 07:02 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
I have mine balanced and then place a small amount of clear silicone over the edges. Works well so far.
Old Mar 21, 2008 | 07:07 PM
Eric Fischer's Avatar
Eric Fischer
I always balance mine and use the stick on weights. I have never had one fall off yet.
Old Mar 21, 2008 | 07:11 PM
nickolbag's Avatar
nickolbag
Won't an ET Street slide on the rim? Wouldn't that make the weights useless when the tire moves?
Old Mar 21, 2008 | 07:22 PM
Paul_Z06's Avatar
Paul_Z06
It's why you screw them.
Old Mar 22, 2008 | 12:05 AM
easyvette's Avatar
easyvette
Thanks for the info. I ended up pulling all the weights off the rears. They were in conflict with the suspension ball joint area. I had no vibrations but never went over 100 at the track...
I still had some traction issues. My first pass I went at 18 lbs and it was ugly no track prep. Second pass went down to 12 lbs and it hooked pretty good off the line and broke free shortly after. 2nd gear I had a nice view of the wall. Just curious to see how low PSI everyone is going with these tires... I had 35 in the front skinnies..
Old Mar 22, 2008 | 01:35 AM
LS1LT1's Avatar
LS1LT1
Hey if that's what you're into that's fine but this is a 'PG rated' board ya know.
Hmm, then again if the tires are really hot....
Old Mar 22, 2008 | 08:47 AM
Paul_Z06's Avatar
Paul_Z06
Trap speed makes quite a bit of difference. I was going faster before the 1/8 mile than you after the 1/4. So, to you weights may not matter as much but in my case it made a significant difference. I ran my car with an unbalaced set of tires one day and I definitely could feel it at the top end.
I ran my ET Streets at 9 lbs. You need to experiment a little. Start high (like 12-15 lbs) and decrease pressure by 1/2 lb every run. See what works best for you. You'll know what the optimal pressure is when you start twisting half-shafts I think your fronts are fine +/- 5 lbs. Keep in mind that lower tire pressure doesn't always translate into a better hook up.
Old Mar 22, 2008 | 12:54 PM
easyvette's Avatar
easyvette
I gotta do some research on the tires and what is needed to heat cycle them properly for optimum grip. Last nite was the first night for the new tires and things didn`t go to well... I see people going well into the 9`s with them so its obvious its not the tire.
To Drag Pack Question
