Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Hey Edgar!
Old Apr 12, 2008 | 10:41 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Hey Edgar!
We have discussed this earlier in a thread but there hasn't been a statement clarifying if following NCC 10.0 rule is in effect or if it was a mistake and this rule does not apply - at least not as stated?
3) No electronics are allowed. Single stage line lock on non drive wheels only. No timed pneumatic or electric shifters.
Delay boxes, transbrakes, two steps and playback tachs are permitted.
Air throttles, used as launch control devices are permitted. Stutter boxes and “timed down track throttle stops” are prohibited.
I'll need to know if I should remove the box or not and if I have to wire my nitrous throgh a relay and not through the box. As we are running on a Pro Tree, a box won't give you a advantage anyways as the delay is usually set to 0.00
Old Apr 12, 2008 | 11:50 PM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
Lemme check with Steve
Old Apr 12, 2008 | 11:58 PM
GrandSportC3
Thx!
Old Apr 14, 2008 | 01:10 PM
REDGAR's Avatar
REDGAR
CI VI Drag Champ!
It might need to be clarified but the delay box in okay in that class.
Old Apr 14, 2008 | 01:23 PM
GrandSportC3
in ok? I assume that you meant is ok - right
Like I said, it's really useless with a Pro Tree anyways but the only reason why I needed to know is because I would have to wire my nitrous differently through a reversed relay to have it come on when the transbrake is released.. Well, I might not need the nitrous at all, but that depends on weather conditions..
Old Apr 14, 2008 | 03:39 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Oliver, you need Nos to run 10.0?
Old Apr 14, 2008 | 03:45 PM
GrandSportC3
Depends on the weather.. I ran 9.90 @ 136.50 in low 70's with low humidity and about 7 mph tail wind.
In 80+ degrees weather with higher humidity, I might only run in the 10's (probably 10.10 - 10.20) on engine. If there's head wind, even slower.. so I might have to spray to be sure to be as close to 10.0 as possible.. the 25+ lbs bottle also adds weight and costs me about .03..
I will have the bottle hooked up and will be ready to spray, even if the car runs 10.0, just in case if I'll spin of the line etc..
To Hey Edgar!
