I'm currently running the CCW drag setup, with skinnies up front and MT ET Streets 26x11.5x16 rears.
I'd like to be able to drive to the track with the MT 315/45/R16 street radials and install the bias ply skinnies at the track.
2 questions:
Are the street radials as good or better than the et streets?
Can I run the street radials on the back and the bias ply skinnies up front?
I tried bias ply rears with radials up front and thought I was dead, it got so loose.
Joe
Does it matter if the fronts are bias ply skinnies?
No shouldn't matter, pumped up bias plies up front with radials out back should feel much better than you former combo of 'slicks out back with stock radials up front'.
Originally Posted by gojo
2003 red vert
Mods:
LS7 crate engine, wet sump, 24xx reluctor
LPE 100mm MAF
Vararam
RPM Level 5 trans, A4
3.42 gears
Yank SS3600
AR headers
Z06 exhaust
470hp 437tq
Can I run the street radials on the back and the bias ply skinnies up front?Joe
I have run my CCW front skinny’s up front and 345/30/18 BFG drs on the back............drove to the track 50+ miles one way. Cracked of 10.9xs and drove home. No fast turns or evasive maneuvers but fine other than that
Your times are just what I would like.
Thanks for the information. I could show off too.
