Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Spinning
Old Apr 22, 2008 | 06:25 PM
Wickd1's Avatar
Wickd1
Default Spinning
Me and a friend are having a debate, If a car spins for 5ft leaving the line, Would his mph be higher than that of same car not spinning?Ive always heard if you spin it will trap a higher mph.
Old Apr 22, 2008 | 07:01 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
MPH trap speed is based mainly on your HP. Spinning off the line will have little effect.
Old Apr 22, 2008 | 07:07 PM
Fartpipe's Avatar
Fartpipe
Spinning on a little will let the car gain MPh faster yes but ET usually suffers. Its not a drastic increase, maybe 1 mph in most cases.
Old Apr 22, 2008 | 07:19 PM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
yup. same car. same setup, all other variables being equal some spin will yield a higher than expected MPH
Old Apr 22, 2008 | 08:09 PM
Glensgages's Avatar
Glensgages
To use a Top Fuel-term, the car might 'get-UP on the tire', and once the car does hook-up, run extremely-well, with a higher trap-speed (probably because the motor gets wound-up earlier/quicker?), but the increased MPH would be marginal, as stated above.
Old Apr 22, 2008 | 09:22 PM
vetteman9368's Avatar
vetteman9368
From: I have no tolerence for liberals and fools, but sometimes i repeat myself
CI 3-5-7-8-9 Veteran
St. Jude Donor '08
yes, for reasons stated above. And since it usually slows down your 60', it give you more time on the track, which can contribute to the marginal increase in MPH
Old Apr 25, 2008 | 07:26 PM
Mark-44's Avatar
Mark-44
Mine does...
Old Apr 26, 2008 | 02:40 AM
rlane5's Avatar
rlane5
IMO if you have a TPI it may hurt you because of the powerband.
Randy
To Spinning
