Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
air pressure
Old Jul 25, 2008 | 11:10 PM
jam1192's Avatar
jam1192
Default air pressure
what air pressure would I run with MT drag radials when racing at the track 305-35-18
Old Jul 26, 2008 | 10:15 PM
jam1192's Avatar
jam1192
I am surprised that nobody could answer this question but after further checking I found that the pressure should be around 12 to 14lbs if anybody is interested
Old Jul 27, 2008 | 08:30 PM
willyszr1's Avatar
willyszr1
please be very carefull of how the car feels on the big end when using below 15lbs . you might start at 18 and work down a lb at a time . at the end let off slow to not unload the tires too much and dont hammer on the breaks.
Old Jul 27, 2008 | 09:34 PM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
Not a whole lot of folks running the 18's. i sometimes run 16" and I don't go that low. No need to. The numbers you have is what a stick shift car might run MT ET Street Bias play tires. I have an auto and run bias ply at 15 cold and radials at 19 or 20 cold.
You coming to join us for the Corvette Challenge at Etown this Aug 2 or Aug 9th?
www.corvettechallenge.info
Old Jul 27, 2008 | 10:09 PM
jam1192's Avatar
jam1192
Im not sure ,how do I go about joining if I can. The numbers I found came from the MT web site I just assumed that it was for automatics
Old Jul 27, 2008 | 10:11 PM
jam1192's Avatar
jam1192
thanks
Old Jul 27, 2008 | 10:51 PM
LS1LT1's Avatar
LS1LT1
I would start at 22 psi and go up or down from there as needed.
Old Jul 27, 2008 | 11:20 PM
jam1192's Avatar
jam1192
What kind of traction will I get at 22psi I was told that the lower psi the better traction I would get. thanks man
Old Jul 27, 2008 | 11:30 PM
LS1LT1's Avatar
LS1LT1
It depends on a few factors such as track prep, air temps and you car's power level but when properly heated those drag radials WILL hook.
Welcome.
Old Jul 27, 2008 | 11:35 PM
jam1192's Avatar
jam1192
Im at 550 rwhp so Ill give it a try when I go to the track at atco raceway thanks
Old Jul 27, 2008 | 11:37 PM
jpee's Avatar
jpee
Up to a point.. TOO low and the tires will "cup" in the middle and run on just the inner & outer edges..
Before you get to the track, try 20 lb and do a small burn out 10' or so... look at the rubber marks on the road.. see if it looks like they are the same color all the way across from one side to the other.. if the edges are darker than the center the air pressure is too low... if the center is darker you have to let more air out..
But as Redgar says with Radials 20 is a good starting point..
I use 315x17 BFG Drag Radials at 18 lb and do fine, but my car is an automatic... Stick shift cars can be more of a problem to get the air pressure just right...
It's a matter of "Trial & Error" but once you find that "Sweet Spot" you air pressure should always be + or - 2-3 lbs...of that #
Old Jul 28, 2008 | 12:44 AM
jam1192's Avatar
jam1192
Thanks I cant wait for the track I have a lot of good advise from everybody ( thanks again everybody)
Old Jul 28, 2008 | 01:01 AM
thesubfloor's Avatar
thesubfloor
From: Brentwood World's first A6 in the 9's (including N/A, blower, turbo and nitrous cars) 9.950@139.267 CA
If I may, I'd like to add to this thread.
To build on what LS1LT1 said (and I'm hoping somebody will back me up on this) there really is no one "perfect pressure" that will give you the best time all the time. I've run at the same track twice in two days and despite all of the conditions being pretty much the same except for the air temps, I've gotten very different 60ft times and subsequent ETs.
If you're bracket racing, another thing to keep in mind is that you don't want to experiment too much during your time trials. The best thing to do is to pick a pressure early on and then try to stick with it because it's consistency that wins trophies, not the best speed.
Christopher
Old Jul 28, 2008 | 01:09 AM
jam1192's Avatar
jam1192
Christopher
THANKS
Old Jul 28, 2008 | 01:47 AM
willyszr1's Avatar
willyszr1
one last addition , having run 2 sets of these for 3 years. on your first run do a really good burnout then do a short burnout on the following runs . if you do long burn outs on everyrun your 60ft times will suffer as it will bring out oils that are in these tires . if you have a manual car as i do you will find i think that 17 is your absouloute low and 21 your high . you might also ck out rangers site he has some very good hints on how to drive your car at the strip . good luck but be carefull if she gets a little squirrely get out of her that run is ruined any way . you can allways make another run . also when your at the strip ask some other vet guys that are there . those of us that have raced for a long time enjoy helping out the new guys . it is fun to see the look on their faces when their car goes way faster than it did before we helped.plus we have a new fellow drag racing addict
Old Jul 28, 2008 | 07:39 AM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
With good track/weather conditions......I have an auto...........so for me, 5 second burnout........22-25psi hot to start. 1.49-1.52 60's all day long
I find the MT drs like more pressure.
I have run 16,17 & 18" bias/drs on C5s
Old Jul 28, 2008 | 10:38 AM
jam1192's Avatar
jam1192
To air pressure
Old Jul 28, 2008 | 10:39 AM
jam1192's Avatar
jam1192
Old Jul 28, 2008 | 02:00 PM
REDGAR's Avatar
REDGAR
CI VI Drag Champ!
You don't have to join at all. Just show up. Pay your entry fee for Corvette Challenge ($30)
Old Jul 28, 2008 | 02:05 PM
chaase's Avatar
chaase
St. Jude Donor '12
I normally run the 17" DRs on 18 cold.
