Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Hot Lapping
Old Aug 5, 2008 | 08:45 PM
c5mtl's Avatar
c5mtl
Default Hot Lapping
has anybody noticed their car running a 1/10th or faster on the 2nd run less than 5 min after the first run...and if so can anybody explain it...it seems to me and a couple of pro racers these ls1's like to run a bit warmer
Old Aug 5, 2008 | 09:38 PM
dennis50nj's Avatar
dennis50nj
you just blew out some carbon, and now your oil temp is at a better temp
98NYFINESTVETTE's Avatar
98NYFINESTVETTE
From: 10.70 @ 124mph, Stock Bottom End @ 3620lbs, ECS Racing Team Member. The 1st NMCA LSX Index Rumble World Champion. 2011,12,13 Champion
I have noticed that my first time shot is slower then my 2nd time shot, even when the weatehr will be worse. For example, My first time shot I would run 11.44, Then on my 2nd time shot I will run 11.43. My TAG weather station will predict a 11.459 for my 2nd time shot.
I think of the 1st pass as a clean out pass. I also think my commute to the track has something to do with it. It takes me 10 minutes to drive to the track, I am sure all the fluids are not warmed up yet.
After my 2nd pass, The Vette is consistent. I almost have it down to a science if for some reason we only get one time shot.
Hope this will help you.
Old Aug 5, 2008 | 10:10 PM
DBN's Avatar
DBN
Default Hot Lapping
I remember last year at one of the last Carolina Corvette Challenges at Darlington SC, we all qualified on the quarter mile and then when it came time for eliminations the quarter mile clocks would not work so we had to switch to eighth mile. We made one qualifying run on the 1/8 and went right back into the lanes for first round. I picked up .05 and 1/2 mph in the eighth between the two passes. My car seems to run best with the water temp above 180 degrees.
Old Aug 5, 2008 | 11:42 PM
c5mtl's Avatar
c5mtl
i totally agree with the water temps...anybody else.....carbon buildup also sounds possible
Old Aug 6, 2008 | 09:58 AM
DBN's Avatar
DBN
Default Hot Lapping
It was not carbon build up for me as these were the forth and fifth passes of the day.
Old Aug 6, 2008 | 11:08 AM
jpee's Avatar
jpee
My LT1 is the exact oppisit... it runs best when its under 160 deg... if it goes over 180 it will slow down almost a tenth...I have a chart, & 2 data bases in my TAG..
One data for running cool, and another data base for HOT runs.. and its pretty close..
Old Aug 6, 2008 | 11:38 AM
vetteman9368's Avatar
vetteman9368
From: I have no tolerence for liberals and fools, but sometimes i repeat myself
CI 3-5-7-8-9 Veteran
St. Jude Donor '08
I could see the aluminum block motors liking a little more water temp for sure because it disspates heat into the coolant so quickly. that lost heat is lost HP. On the other hand we try to go to the lanes with our iron blocked stocker at less than 100degrees water temp, but the oil is warm
Old Aug 7, 2008 | 03:32 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
True dat
I hot lap and I will lose up to .20 in the 1/4.
I launch at 130 to 140 after cool down .My lt1 is the same way but I put 2 trans coolers on the 4l60e on the lt1 and it doesnt lose anything in the 1/4 that I have noticed like before the install.
Old Aug 7, 2008 | 09:50 AM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
My LS1 did and LS2 does the same. That is unless it is the third consecutive then it might tend to slow and the fourth hot lap will usually be slower.
It has a sweet spot.
Old Aug 7, 2008 | 12:55 PM
pr1mu5's Avatar
pr1mu5
Old Aug 7, 2008 | 05:15 PM
Dr.Ron's Avatar
Dr.Ron
From: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
My C5Z would run faster on the 3rd or 4th hot lap then the 1st or 2nd.
My C6Z can't run fast hot PERIOD!!!
Ron
To Hot Lapping
