Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
LTX Shootout
Old Aug 5, 2008 | 11:55 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Default LTX Shootout
I got to hit this next year
http://www.gmhightechperformance.com...age/index.html
Jeff Green swapped out his Opti in under two hours after the rotor pin let go to qualify, but was only able to coast to an 11.20 after the transmission let go-way off his best of 9.50 at 150 mph. Unknown to Jeff at the time, the cam pin had also sheared, which probably resulted in the wheelhop that broke the trans and bent the rear sway bar. If you're wondering, that's not silver paint on that block, it's a 446ci aluminum Donovan that's been welded and milled into the shape of an LT1 block, making 1,300 horses with the factory OBD-I PCM! Jeff has kept this 4,400-pound beast as stock as possible and even runs the original 10-bolt rear housing. We will go into detail on this amazing car in an upcoming feature.
Old Aug 5, 2008 | 11:59 PM
nomrlz's Avatar
nomrlz
atleast they finally found a good use for the opti. good idea, bad location
Old Aug 6, 2008 | 12:02 AM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
I read that too. Pretty impressive those guys pulled it off.
Old Aug 6, 2008 | 11:36 AM
BrianCunningham
I'm actually still on my original opti with 140k
Though I did a cap & rotor @ 110k
Of course I have the later vented one.
To LTX Shootout
