Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Quickest IRS C3
Old Aug 9, 2008 | 11:48 PM
markshaw70redBB's Avatar
markshaw70redBB
Default Quickest IRS C3
I'm trying to find out who holds the quickest true IRS 1/4 ET & MPH for a C3 corvette. Maybe Mike Sakia, Steve Hoch, or Greg Eaton?
Anyone have any verifiable facts.
I ran an 8.8 @ 156.23 today so I figure I have to be close to being in the top 10 or so.
Old Aug 10, 2008 | 12:30 AM
INSANITY's Avatar
INSANITY
Mark I hope its You... Ben and yourself are TOP NOTCH people.....
You go out of your way to represent... And have a great ride..
Old Aug 11, 2008 | 07:46 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Congrats on the new best!
Greg Eaton has gone 8.58 @ 161.17. Recently, he has improved his best naturally aspirated ET by a tenth or so and with some additional changes that he is doing, he is hoping for 8.40's or better...
Red79Vette454 has gone 8.88 but has switched to solid axle since..
I haven't sprayed the full shot of nitrous yet but I should be in the 8.9x range with the full shot and good air. I'm thinking in going with 18 degree heads and a bigger shot next year which should get me into the mid 8's...
Old Aug 11, 2008 | 09:46 AM
markshaw70redBB
Olivier -
Do you know the info about Greg Eaton? I tried a Google search but can't find anything. I'm curious to know if his car is truly a street car like mine or more a potato chip that has been been stripped and lightned. I weigh 3550#.
Old Aug 11, 2008 | 04:07 PM
RacerX70CC's Avatar
RacerX70CC
Ever get that engine noise figured out yet? I'd hold off on the spray till you do (unless you want to drive over the crank)
Old Aug 11, 2008 | 04:52 PM
vetteman9368's Avatar
vetteman9368
From: I have no tolerence for liberals and fools, but sometimes i repeat myself
CI 3-5-7-8-9 Veteran
St. Jude Donor '08
was there ever a doubt?
Old Aug 12, 2008 | 06:49 AM
Beach Dude's Avatar
Beach Dude
Mark, I think you would be in the top 10 easy, is your car registered and insured as a true street car? I know some that claim to be street cars, but are not registered/insured for street duty, Great numbers though, Congrats.
ps, Glen I missed my guess
Old Aug 12, 2008 | 08:22 AM
markshaw70redBB
The car was registered until this year when I decided to turn in the plate. It still has the collector insurance on it. Only the slicks make it illegal for the street at this point. Although I would need to put the front sway bar back in if it was to spend any amount of time on the road.
Old Aug 12, 2008 | 09:04 AM
GrandSportC3
Originally Posted by markshaw70redBB
Olivier -
http://home.earthlink.net/~geaton
He runs a 427 SBC with 23 degree Dart 220 heads, making well over 700 HP naturally aspirated.. I believe that he is running a 400 HP fogger but I'm not sure if it's a 400 HP shot or less.. He posts here and has posted details of his setup.. Here's one of his posts..
http://forums.corvetteforum.com/show...2&postcount=42
Do a search on his posts.. He has posted more details on his setup before..
Old Aug 12, 2008 | 09:08 AM
GrandSportC3
I didn't have any time to work on the race car.. I'm busy with tons of stuff and I haven't even had a chance to pull the pan and check the bearings... I hope to have a chance to work on the car some time in September..
Old Aug 12, 2008 | 09:12 AM
GrandSportC3
Would your car run on unleaded fuel? It's theoretically illegal to drive a car with leaded fuel on the street (even though I MIGHT have done that before )..
Mine is street legal too but with the 5 gallon fuel cell, I wouldn't get too far and the car is running on 112 leaded (or higher if I spray the car)...
Old Aug 12, 2008 | 09:13 PM
Beach Dude's Avatar
Beach Dude
My hat is off to you, running those kind of numbers with a car that is still streetable and the weight.
Old Aug 12, 2008 | 10:55 PM
4DRUSH's Avatar
4DRUSH
I enjoy just looking at Mark's car. It's a super nice top notch build done by a top notch guy.
Old Aug 13, 2008 | 05:39 PM
69 N.O.X. RATT's Avatar
69 N.O.X. RATT
From: Pettis Performance 565 with two stages of Nitrous Supply nitrous 1.082, 4.61 at 155, 7.17 at 192
Olivier -
Sweet car, what is the basic engine and tranny combo ??
Old Aug 13, 2008 | 10:58 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Yo Ollie.....I guess I missed it...what happened to the motor?
JIM
Old Aug 14, 2008 | 06:52 AM
markshaw70redBB
Original 4 bolt 454 block from 1970 now a 511 ci with Callies crank, Oliver rods, Diamond pistons, Brodix Race Rite heads (major work), T&D shaft rockers, custom Comp Cam, lifters and springs, Comp Cams timing belt, MSD crank trigger. Reher-Morrison did the custom intake with Edelbrock Pro fogger, Holley 1050, etc. It's a bullet proof piece built to my specs by PK Machine in Fitchburg, MA.
TH 400 with reverse manual valve body and trans brake built for me by H&H Transmission of Wallingford CT. Converter is from Transmission Specialities and is their 10 1/2 inch Cadillac with a 5000 stall.
Old Aug 15, 2008 | 02:20 PM
GrandSportC3
JIM
I don't know if anything happened.. At the National Corvette Challenge, I heared some knocking from the engine but it went away..
Now, I don't have any noise but my oil pressure is not as steady as I'd like it to be. .However, my idle is rough and the slightly bouncing oil pressure could be a result of that.. In a few weeks, I'll pull the pan and check the bearings just to make sure..
Old Aug 16, 2008 | 12:09 AM
PRNDL's Avatar
PRNDL
wow, you really have that thing moving! I remember when you ran 12.00 on a 12.00 dial (pre-rollcage). That was only a few years ago.
Old Aug 17, 2008 | 12:48 AM
2000-A4's Avatar
2000-A4
Olivier -
My car has a spool and 13:1 CR so i would not consider it a "street" car, although the headlights not only work they open & close on their own when the lights are turned on. The parking lights work, brake lights work, reverse lights work, turn signals work, etc. The car has full interier, electric windows, Auto Meter gauges are mounted in the original cluster (tach, temp, oil, vacuum) and the shifter is mounted in the original location using the original shifter plate (looks like it was installed from the factor).
The car runs 8.50's with a SB, single fogger and on 29.5 X 9 ET slicks.
To Quickest IRS C3
