Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
CCW drag pack gains?
Old Oct 4, 2008 | 03:45 PM
95vettski's Avatar
95vettski
Default CCW drag pack gains?
For all you bracket racers or 1/4 junkies who have their cars dialed in, what gains have you seen with a CCW drag pack? Is the weight savings and less rolling friction up front worth any mph? I'm trying to compare the CCW's to stock Z06 wheels that are already lightweight.
Old Oct 4, 2008 | 08:01 PM
Dave-T's Avatar
Dave-T
I recently purchased a CCW radial drag pak. I am using Hoosiers in the rear. I previoulsly had stock Z06 wheels with BFG drag radials. The total weight savings was 10lbs at each corner for a total of 40lbs. The Hoosiers hook real well but so did my BFG's. As far as ET gains it is kinda of hard for me to say since I don't have a lot of data. However my guess is the gains are very minimal. That is I think the gains would be in just the 40 lbs. Some people say that 40lbs in rolling weight is equal to 3 times that of non rolling weight. But I don't see a ET increase of 120lbs. So to make a long story short I think I am only seeing a gain of about 0.04 seconds in the 1/4 mile.
Old Oct 4, 2008 | 08:44 PM
robz's Avatar
robz
I tend to agree with Dave.
Different cars will react differently to a drag pack also depending on HP, stick vs auto, overall setup.The weight savings will help for sure but I I agree with dave on the amount.
Skinnies allow you to run the car all out and not have to worry about being all over the track on the big end.
Old Oct 4, 2008 | 09:35 PM
dennis50nj's Avatar
dennis50nj
it was hard to keep the car straight, now its has no drift side to side
Old Oct 5, 2008 | 02:06 AM
LS1LT1's Avatar
LS1LT1
The drag pack certainly helps but it's not the 4/10ths plus reduction all by itself that some people claim unless one is starting with huge, heavy 22" blingy rims with 400+ treadwear tires on them LOL.
Also keep in mind that there are variations on what actually constitutes a 'drag pack' as well, some have radial tires and some have bias ply tires and some have a combination of both.
Radial based versions often weigh more than bias ply versions.
Old Oct 5, 2008 | 09:23 AM
CYA-Vett's Avatar
CYA-Vett
So in a nutshell, if you're not a hardcore 1/4 mile racer, the price does not justify itself...Unless your super rich, like Ronnie...
Old Oct 19, 2008 | 11:06 PM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
I bought robz's old drag pack with Bias Ply MT on the back. I picked up maybe a 0.05-0.1 drop in my 60ft times, but other than that not much of a difference coming from a 275/40/17 drag radial.
Old Oct 20, 2008 | 07:10 AM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
I have done lots of tire/wheel testing on my 97'
In a nutshell, here are my results and specific threads about it
I have lost exactly 1/10th with loosing 84 lbs rotating mass
from my street setup 275/35/18 & 345/30/18 to a CCW drag pack
Seat time will only help the 60's
http://forums.corvetteforum.com/show...ight=drag+pack
http://forums.corvetteforum.com/show...ight=pack+drag
To CCW drag pack gains?
