Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
front wheels
Old Nov 13, 2008 | 08:26 PM
Cruzzn's Avatar
Cruzzn
Default front wheels
Why? Should you run skinnies tires on the front?
rod
Old Nov 13, 2008 | 08:33 PM
MTVette's Avatar
MTVette
I've been wondering what kind of improvement I might see if I put on skinnies.
Old Nov 13, 2008 | 08:36 PM
Corvette Chris's Avatar
Corvette Chris
rod
Less rotating mass on the front axle. Less weight = better ETs. I haven't tried skinnies on my car yet, but I've heard .1 gains are common.
Old Nov 14, 2008 | 09:21 AM
PDQUIK95's Avatar
PDQUIK95
From: Portsmouth Virginia 396LT4 435RWHP/400RWTQ Best so far 11.26 @ 123mph
Something else people should think about in addition to less rotating mass is that when using skinnies over wider tires it should reduce the amount of water you pick up going thru the water box unless you can drive around it every time. The potential for rear wheels picking up water from the front wheels after your burnout is possible when rolling forward to the line causing tractions problems when launching.
RG
Old Nov 14, 2008 | 09:34 AM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
Yup good point
Old Nov 14, 2008 | 10:18 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
The gains in ET depend on what kind of weight savings you are getting.
Going on a C3 with steel rallye wheels and 255/60R15 steel belted radials to a 15 x 4 Convo Pro with a bias-ply front skinny, you'll pick up .15 or more just with the skinnies..
When I had my old 383 and the 5-speed in my car, I went from 12.08 @ 115 mph to 11.67 @ 119.79 mph by just changing to front skinnies and bias-ply rear tires on light weight wheels (from Drag Radials on heavy wheels). My 60' time acually slightly slowed down with bias-ply compared to the drag radials..
Old Nov 14, 2008 | 04:29 PM
LS1LT1's Avatar
LS1LT1
Excellent point.
Old Nov 14, 2008 | 05:04 PM
ARCH's Avatar
ARCH
I saw big difference with front skinnies. Best I ever got with slicks on rear and regular tires on front was 12.1 or so, best with slicks and front runners 11.85. Of course I don't have enough runs with each to put a firm number on improvement. With the stock C-3 wheels saved almost 50lbs with front skinnies.
To front wheels
