Yes. he will be going deep. He is much better at the pro-tree than the full tree. Like you, he can go .001 to .005 on a Pro-Tree at will. He doesn't do it in the bracket racing because he doesn't want to show off.
Originally Posted by 98NYFINESTVETTE
Whats up with the R/T's??
If he will go deep, you need to add .07 to .08 to the ET.
I will add 1.595875% to the throttle to compensate.
You can tighten that up a little. You think a 11.51 will get you tho the finals?
Based on your advice I will subtract .005975% throttle so that he can run a perfect .50 with a 2
Nice, apparently the Fischers will be serious contenders for sure.
Yes, on some days it will be enough and on some days it might not be, depends on the light each has cut and of course one's ability at tricking their opponent a little, perhaps even getting them to break out.
Going to be a fun season either way.
