Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
drag alignments?
Old Apr 16, 2009 | 12:21 PM
BTHRB4U's Avatar
BTHRB4U
Default drag alignments?
does any one have any recommendations as far as an alignment for a drag set up goes?
Old Apr 16, 2009 | 12:36 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
It depends on what model Corvette you have.. Ideally, for the best performance at the drag strip, you don't want any camber change in the rear. I don't know about C4 - C6's but on C3's, you can get a bracket or smart struts that mount the strut rods so that they are parallell to the half shafts. That setup will prevent camber change and you can set the rear tires to zero camber and zero toe
For the front, ideally you have to figure out how high your front end sits while going through the traps. A photo will help greatly.. Then, when doing the front end alignment, the front tires should be set to zero toe and zero camber at approximately the same front end height as when going through the traps..
This setup will
a) plant your rear tires firmly, even during squatting
b) have the least rolling resistence
Old Apr 17, 2009 | 05:48 AM
BTHRB4U's Avatar
BTHRB4U
Yeah sorry for not mentioning what i have, its a 99 FRC, with 18's all around and drs on the back, lowered on stock bolts.
thanks for the good info, its a starting point! anyone know about the C5's?
Old Apr 17, 2009 | 10:54 PM
Howard Wolf's Avatar
Howard Wolf
If you live within driving distance of
Ft. Wayne, IN, get Phil at DTE Powertrain
to do a "dynamic alignment" on your car.
260.407.5455 He'll make it launch great
and go straight.
To drag alignments?
