A4 launch question - newb needs help
If I do a break/torque to about 1200 the car "bogs" or hesitates occasionally (seems more common when hot) when i let off the brake and step on the gas. Any idea why?
Sometimes the car begins to "creep" at the at 1200 RPM and other times it holds tight. The brakes, and lines are almost new. Any ideas?
What would be a good release RPM , using drag radials, if the brakes and engine were consistent?
Smash the throttle from idle and your on yor way with a pretty good reaction time. Two foot it , One on the brake the right slightly on the gas ready to go... The staging / launch and reaction time usally determines the race is over in the first 60 ft
ps Make sure if you start racing in a series ... What type of light they run Sportsman or pro tree.. you look out of place when you smash the throttle on the first yellow of a sportsman tree
do that a few times so far
