Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Night Racing
Old Jun 15, 2009 | 12:15 AM
Canadian_Goat's Avatar
Canadian_Goat
Default Night Racing
Its been years since I ran at nite and only did it once. Do you guys typically find quicker times when running in the nite air?
Bob
Old Jun 15, 2009 | 12:32 AM
383vett's Avatar
383vett
Air is better, but traction may go away. In the bay area, moisture goes up at night which compromises traction.
Old Jun 15, 2009 | 12:53 AM
Canadian_Goat
ahhh---yeah pretty damp around your area huh? Ive run 12.92 and put a couple more mods on--hoping to run in the mid 12's and thought Id try some nite air.
Bob
Old Jun 15, 2009 | 02:50 AM
LS1LT1's Avatar
LS1LT1
Same thing out here as well, especially during the colder months. It's a little cooler at night but often more humid with a potential loss of traction, a bit of a trade off.
Old Jun 15, 2009 | 09:49 AM
WEB AIR's Avatar
WEB AIR
Bob
To answer your question typically you'll run faster at night. DA and temp drops and humidity will go up. The key is the DA drops and the track is cooler. We had 130 track temp Sat but Sat night we all ran much quicker. DA dropped from 3100 to 2000. Most of us picked up .200 even though humidity was high.
Old Jun 15, 2009 | 09:50 PM
Canadian_Goat
What is the exact method of determining DA?
Old Jun 15, 2009 | 10:22 PM
vetteman9368's Avatar
vetteman9368
From: I have no tolerence for liberals and fools, but sometimes i repeat myself
CI 3-5-7-8-9 Veteran
St. Jude Donor '08
a weather station. kestrel makes some good ones for a couple hundred dollars
Old Jun 16, 2009 | 12:44 PM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
If you are up in Canada, you should run quicker at night...down here it gets so hot during the day the DA is stupid high...then it usually drops in temp to the low 80's at night while we are running...at 4AM it gets all the way down to 74 or so...lol...
Even though the humidity rises like crazy here at night it it is still cooler so we run a bit better...typically at night we have a temp of 82 and humidity of 80 to 90%...the cars get so much dew on them we have to wipe constantly like it is raining...by 10 PM it's ridiculous...
Old Jun 16, 2009 | 02:50 PM
kazman's Avatar
kazman
Fuzzy, did you notice that when it hits the dew point you no longer go any faster with an increasing "better" DA?
Old Jun 16, 2009 | 03:42 PM
Dave-T's Avatar
Dave-T
We have seen this at E-Town. I have actually seen the DA get better but the cars slow down. I guess it is a result of the increased amount of water granules in the air.
Old Jun 16, 2009 | 05:29 PM
Canadian_Goat
Thats cool to hear--I am in the extreme southern Ontario region (just across from Detroit). In July and August it can get hot here too in the 90's with humidity in the 80's as well. We are the humidity capital of Canada here. But those conditions usually dont last all summer--we do get breaks of weather in the 70's and 80's a bit then.
To Night Racing
