suspension mods
motor is a forged 408 making 500 rwhp and i'm running a 200 shot
trans is a rpm level 6
converter is a yank 3400
rpm diff stage III with quaife.
drag pack with 26 x 11.5 et streets
what do we do for suspension on the c5's??
some say lowering will help you 60' but mine is stock height and have gone 1.37
Search though this section for pfadt and ECS they have come out with some new products recently.
I've blown both rear coil-overs with this setup and was asked to take my car off the track at an event for leaking oil (from a blown shock). And, although the shocks were replaced at no charge, the labor was not. Therefore, until Pfadt works out what's happening with the rears, I am not sure I would recommend their coil overs on the rear.
I believe that Pfadt is a good company that designs good parts and am not complaining - I'm still using them (with dampening now set to max). I'm sure they will work to correct whatever may have caused this. But, you may want to contact them prior to running coil overs to chat about this.
I also know that ECS has been testing the Pfadt setup and may be able to offer more insight / advice.
This is just my opinion... But, feel free to blast away at me
My C5: Forged 346 with Paxton Novi 2000, RPM tranny, Getrag 3.42 Diff. (going up to a 3.73), Yank 3200 (going to a Yank Pro 3800), 26x11.5-16 rear tires, etc... weighing in at 3600 lbs with driver, producing ~770 RWHP & 687 RWTQ
As it sits now, the car is usually in the 1.55 range for 60'
I think the change in converter and gears will do more for my 60's than the rear shocks... But, only time will tell
No... I've never run her at 100% -- Typically, I am running between 60% and 80%, depending on the weather.
But, we digress... This thread is about the suspension. So, I shall shaddup now... Even though I do like powahhhh
i give myself a headache thinking about it all.
But, I suggest that you try a few runs before any more mods. There is a good / recent thread on this that you can read at:http://forums.corvetteforum.com/drag...ag-racing.html
Some of the seasoned drivers provide some good insights in that thread. First find out how much you like racing and then after getting some seat time, figure out what mods (if any) you want to do first, instead of going right to the suspension. Otherwise, you may end up replacing mods, which will cost you more in the long run.
With the power adders you mentioned, you may need a roll bar / cage well before a suspension ;-)
Good Luck!
Last edited by digivex; Jun 23, 2009 at 07:45 PM. Reason: cause I wanted to edit it
