Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
C4 DRM brackets ?
Old Jun 10, 2010 | 09:13 AM
rodj's Avatar
rodj
Default C4 DRM brackets ?
Asked this over in C4 Tech and got no response.Have PM'ed randy @DRM but waiting for reply
I have my DRM brackets installed and about to get alignment.
Do the brackets correct things enough to maintain tire contact through travel good enough with stock susp settings or is there a better camber setting to achieve this?
Setting up for a track day so have no concerns as to tire wear ; only looking for optimum contact patch
Have bumps stop to limit travel keeping half shafts level under load at launch.
Old Jun 10, 2010 | 04:30 PM
383vett's Avatar
383vett
Hey Rodj. I used to have the brackets on my C4 when I had the IRS. By "track days", do you mean the strip of a road course. If you meant the strip, set the camber to zero. The brackets will decrease the amount of camber change, even if the car squats an inch or so. You'll have pretty much full contact when the car launches. I can't help you with a road course since I can't turn.
Old Jun 13, 2010 | 04:04 AM
rodj's Avatar
rodj
Straight line only
I thought maybe some might have had the wheels leaning out static so camber came back to zero on launch
Old Jun 13, 2010 | 09:34 AM
lgaff's Avatar
lgaff
2022 Corvette of the Year Winner -- Modified
2021 C4 of the Year - Modified Winner
Do these things help? Any #s to support?
Old Jun 13, 2010 | 01:42 PM
383vett's Avatar
383vett
They help a lot for drag racing. Normally when the rear squats, the negative camber of the rear wheels increases and the contact area is concentrated on the inside half of the tires. With the bracket the strutrods are closer to parallel to the halfshaft and the camber change is minimized.
Old Jun 13, 2010 | 01:43 PM
383vett's Avatar
383vett
Originally Posted by rodj
Straight line only
Probably could try a quarter of a degree and see what happends. Just watch the wear on your slicks as they accumulate runs.
Old Jun 13, 2010 | 10:27 PM
rodj's Avatar
rodj
Strangely for a car with a non optimum drag suspension ( hard Z51 ) my '87 has always hooked good even with the old ZZ4 camed TPI; 1.8 60's
But because the bum goes down on launch ,I only had the inner 4" of the tire making contact with the strip at launch.
Hoping the brackets and the bump stops to limit travel ( stop halfshafts going past level ,stressing the uni's ) will get me a better tire footprint now I have 400 RWHP
Old Jun 13, 2010 | 11:33 PM
383vett's Avatar
383vett
My 84 used to do that when I was running the irs, but the brackets did help. Maybe some +camber is a good idea.
To C4 DRM brackets ?
