From: Brentwood World's first A6 in the 9's (including N/A, blower, turbo and nitrous cars) 9.950@139.267 CA
Originally Posted by WEB AIR
I'm pretty satisfied with the performance of my stock Vette but I need to improve on these .077 lights. Any suggestions?
If you've got a method that works and you just need to make them slightly better, just experiment with launching at a higher RPM until you find the value that works best.
Originally Posted by kazman
I would deep stage too. Down side is that it will drop your MPH a bit.
Deep staging won’t necessarily guarantee you a good light though as I can cut killer lights while staging as absolutely shallow as possible.
Like I said earlier, if you’ve got a system that works (i.e. you’re able to stage the same way every time and already cut decent lights as it is) try experimenting with your launch RPM.
LOL. That's a time slip from a friend that was crew chief for Doug H. That was run by Doug in '08 and I just find this stuff amazing so I wanted to share it. Thought you guys would enjoy seeing the numbers.
