Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Drag Questions!
Old Jul 9, 2010 | 06:55 PM
patches228's Avatar
patches228
Default Drag Questions!
Ok I Have the Following:
2007 LS2 M6
STOCK Rims(The Main Problem)
Toyo R888(Front) T1R(Rear)
220/230 Cam
A&A V-2 Supercharger Kit
LGM Longtube Headers
Corsa X-Tream mufflers
Hurst Short Shifter
610RWHP 536RWTQ
So here is the question, I want to know a good rim choice to put on the rear at the track. I want some pretty decent sized meaty tires. Also how do I get around the TPMS? Can it be defeated by going into Comp mode, or by holding the button? Also With the mods I have will there be any drive train issuses due to increased grip? I have drag raced the crar several times before but now I want to see what it can really do when it hooks!
Any help will be grand! Thanks!
Old Jul 10, 2010 | 02:20 PM
patches228's Avatar
patches228
bump
Old Jul 10, 2010 | 05:16 PM
MikeV's Avatar
MikeV
Hi John
I presume your going to run at Fontana. I don't see a roll bar in your car? If you don't have one, don't bother with the tires. The first time you run faster than 11.50 they will ban you from running. If you have the roll bar, look into some ccw wheels, and some large M/T ET streets. That should put you into the 10's. Just watch out for broken shafts if you haven't upgraded.
Hope this helps.
Mike V
Old Jul 11, 2010 | 02:05 PM
patches228's Avatar
patches228
Thanks for the info Mike. You think a carbonfiber shaft? Is the stock rear ok?
Old Jul 11, 2010 | 03:59 PM
2003VETT's Avatar
2003VETT
From: Still the Fastest (still running) Stock Bottom End Blown LS1/ 2010 ECS CC 10.50 CHAMP Hamilton, NJ
Im running the ~same numbers and I use STOCK front wheels 17X8.5 with M/T 275/40/17 drag radials and have no prob hooking at all.
Old Jul 11, 2010 | 04:31 PM
LS1LT1's Avatar
LS1LT1
I think he actually means the shafts (output shafts) in the rear, not the driveshaft (which is located inside of the torque tube and available in carbon fiber as you'd mentioned). There are no carbon fiber output shafts as far as I know.
Yes the stock rear is ok for stock/near stock power levels or even for regular street driving at your power level but you will likely need to upgrade to some more 'hardened' internals if you're going to be drag racing it on stickier tires.
Old Jul 12, 2010 | 12:52 PM
MikeV's Avatar
MikeV
Output shafts, not drive shaft. You might want to get a DTE brace for the differential also.
Mike V
Old Jul 20, 2010 | 08:38 AM
larry00's Avatar
larry00
Spicer offroad U joints are a good upgrade since you likely don't have a drive shaft loop ! A wayward driveshaft can cause a lot of dammage !
Old Jul 24, 2010 | 02:08 PM
MikeV's Avatar
MikeV
Don't think its required with a torque tube?
Mike V
Old Jul 25, 2010 | 07:40 AM
juicedz06's Avatar
juicedz06
install C5 rear axles
To Drag Questions!
