Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Slick?
Old Mar 13, 2011 | 09:16 PM
coolhand5599's Avatar
coolhand5599
Default Slick?
I put Hoosier 28 10 17 slicks on my C6 with around 600hp on an A6. I left the stock front wheels on. We were at an 1/8 mile I ran 6.9 with the *** end moving around very bad. I would of never made it to a 1/4 mile. And I did not pick up anything from the Nitto NTO5Rs. I had the tire pressure from 16lbs down to 10lbs. Nothing changed. What would cause the car to move around so bad? If it matters I have the F55 and I had it in sport
Old Mar 13, 2011 | 10:03 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
I'm guessing you had full size fronts on? If you're going to run Bias plys in the back, you really need skinnys up front.
Old Mar 13, 2011 | 10:08 PM
coolhand5599
Really, why is that?
Old Mar 13, 2011 | 10:13 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
even when driving down the street, any irregularities in the road will have a tendancy to occasionally make the car feel like it wants to dart from side to side a bit.
When that happens on the track and you have Bias out back, the darting gets exaggerated though the stiffness of the chassis and because the softness of the sidewall on the bias there is nothing to keep it from swaying back and forth. it will get worse with each sway until it is uncontrollable. I've seen guys go from the left lane to the right wall because of it.
Old Mar 13, 2011 | 10:32 PM
coolhand5599
Would front skinnys take care of it totally or would it be good to add tubes as well?
Old Mar 13, 2011 | 10:35 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
Skinnys should take care of it. Radial skinnys are fine, but they are heavier than the bias skinnys.
A lot of cars run Bias out back and radial skinny up front. Works good, lasts a long time...
Best of success with your goals!
Old Mar 13, 2011 | 11:06 PM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
I am not a fan of bias on back and radial on front...neither is any tire manufacturer..not stable, particularly the faster you go...
I don't know what weight your car is but I run Hoosier slicks out back and use 14 lbs. in them...my car is 3700 lbs. with me in it....remember, the rule of thumb is to run as much pressure as you can and still hook...
Are those Nitto's radial slicks or bias ply?...if they are radial slicks you need to try 25 lbs. and work from there...if they are bias, get some bias skinny's up front and then 16 lbs. in the slicks should be a good starting point...
Old Mar 14, 2011 | 08:05 AM
CYA-Vett's Avatar
CYA-Vett
I used to run my car with bias in rear and radials up front, yes its all over the place. You will get used to it. The first few passses do feel quite odd though...
Old Mar 14, 2011 | 09:17 AM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
I concur you want to be driving that with front bias skinnies with that much rear tire
To Slick?
