Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Help with Shift Points
Old Apr 23, 2002 | 05:44 PM
The One's Avatar
The One
Default Help with Shift Points
Hey guys - using my most recent dyno graph (the RED lines,) at what RPM should I be shifting?
I currently shift just before the limiter (6100-ish - yes, I tap it every now and then :bb) and it's netted me a best of 12.5@115 with crappy - but consistent - 2.0 60' times. I know my 60' needs work, but was wondering if changing the shift points will yield any benefits. ;)
JC
Old Apr 23, 2002 | 07:38 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Help with Shift Points (The One)
Your an A4????????????
And what rear do you have?????????????
Old Apr 23, 2002 | 08:04 PM
The One's Avatar
The One
Default Re: Help with Shift Points (mackeyred96)
6-speed with 3.73 gears.
Old Apr 23, 2002 | 08:42 PM
mackeyred96
The shift points should be fine, but that 60' needs to come way down.
Old Apr 23, 2002 | 09:03 PM
The One's Avatar
The One
Thanks mackeyred96. I'm finally getting 1.9s. Still not great :rolleyes:, but workin' on it! ;)
:cheers:
JC
Old Apr 23, 2002 | 09:50 PM
Power Shifter's Avatar
Power Shifter
The only real way to know what is going to work best for you is to try differant shift points. Trying lower shift point can some times pay you a divedend in MPH with no loss in et, and some times a better et. Some times hiting the limiter in bracket raceing is not a good plan, depending on the competion an terrable plan. Ric
Old Apr 23, 2002 | 11:14 PM
DragMan's Avatar
DragMan
Default Re: Help with Shift Points (Power Shifter)
what is limiter set at in stock 1993 Vette about 5600???
Old Apr 23, 2002 | 11:33 PM
The One's Avatar
The One
Thanks Ric. Would you recommend lowering the 1-2 shift only (what, about 2-300 RPM?) or all 3 shifts? BTW - I never really "plan" on hitting the limiter. ;) :lol:
JC
Old Apr 24, 2002 | 12:41 AM
Power Shifter
JC, Dyno's are only good for tuneing the motor. I recomend trying differant points on all the shifts but one at a time on each run, compare the differance in times 60-330, 330-660, 660-1000 ect. It will tack you time but will likely reward you for the effort. Geting into high gear sooner if the car has the TQ is a rule of thumb, but trying it is the ONLY real way to know what rpm on each shift. Ric
Old Apr 24, 2002 | 11:54 AM
The One's Avatar
The One
Thanks again, Ric. I have seen numerous references to power and torque curves on this forum regarding shifting to keep the car in the sweet spot, hence this post. I do value and appreciate your advice, though. Looks like there are a few experimentation runs awaiting me. :D Thanks! :cheers:
JC
Old Apr 24, 2002 | 02:01 PM
ODennis's Avatar
ODennis
Hi all,
I'd like to recommend the book AUTO MATH Handbook by John Lawlor. in the opening paragraph of the chapter named Shift Points he states "To get the best acceleration out of a high-performance vehicle during shifts, hot rodders say you should stay 'on the cam.' What they mean is that you should keep the engine within an rpm range where the transmission is delivering optimum torque before and after each shift."
He provides formulas to determine optimum shift points.
Good luck!
To Help with Shift Points
