Bit by the whatever last year and did a fair allthough expensive NA build this spring.
LSX 454 little over 600rwhp NA and a 100 shot to start that i hav'nt even tried yet.
'06 C6 with stock suspension and 6sp.
Diff gone thru by DTE with 3.73's and a quaife
Even with a new set of NT05R's,no traction unles i really baby it in 1st. and 2nd.....Any suggestions would be welcome!best time albeit just once to the track so far 11.6 range/126mph.
Yeah that's A LOT of power and especially so with the hard hit/big torque numbers of a big inch motor with nitrous. And through a manual no less.
The NT05Rs are 18" I assume?
It's going to be difficult to find traction with that combo plus a stock suspension on any tire but you might have to look into a 17" drag radial (maybe a 295-45-17) or even the 17" ET Street bias plies (26-11.5-17).
Thank's for the reply's so far, added info that i should have mentioned,duh
LG spindle kit ordered to run 15in. rim/tire combo
considering Pfadt drag coil-overs,better choice if any?
with 15in rim's...DR or actual slick's?..ideas welcome!
seems like u'd be tickling if not into the 10's soon I bet, good luck, hang in there like a hair in a biscuit I'd like to trip the lights myself with my STREET ride, I need suspension and tire tips 2000 non-zo6 auto LPETT650 2800 yank conv 345-30-19 (may try to used whl/tire affordably ?is which} fronts 255-40=18's see spec in file, any thoughts I'm more of a turn left driver but divorced my pit crew
