Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
SAFETY:Harness Question
Old Aug 21, 2011 | 01:42 PM
ron-kim's Avatar
ron-kim
Default SAFETY:Harness Question
Deciding on Harness to order from Summit , Question is: Should i go with single or dual point mount at roll bar for shoulder straps?
'06/C6 with factory seats..Thank's for any input.
Old Aug 21, 2011 | 01:59 PM
4DRUSH's Avatar
4DRUSH
Without seeing your set up I would say dual point.
Old Aug 21, 2011 | 02:02 PM
ron-kim's Avatar
ron-kim
Holt 6 point with swing out door bars
Old Aug 21, 2011 | 08:51 PM
ron-kim's Avatar
ron-kim
Hmmm,at this time 28 views and only one comment(i do appreciate it 4D),really did'nt think it was that stupid of a question?
Old Aug 21, 2011 | 09:02 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Always dual, much easier to install.....
Old Aug 21, 2011 | 09:08 PM
ron-kim's Avatar
ron-kim
Thank you sir
Old Aug 21, 2011 | 09:31 PM
4DRUSH's Avatar
4DRUSH
Attaching it to the roll bar is the easy part. You'll most likely attach the waist bans using the stock seat belt bolts. If I remember correctly you have to bend those tabs a little & drill them out?
Also technically you should have a slot in your seat, because the crouch belt has to be fastened to the floor behind your crouch & come straight up.
You really should add another piece of plate steel underneath from outer frame to inner frame for the crouch strap fastener. (the floor is just thin sandwiched wood) At least use a big fender washer.
Old Aug 22, 2011 | 08:13 AM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
I kind of lean toward RCI Platinum if you haven't decided on a brand yet...you get 4 years out of them for the same price as 2 years with the others...
Old Aug 22, 2011 | 08:15 AM
Fuzzy Dice's Avatar
Fuzzy Dice
dupe...
Old Aug 22, 2011 | 06:26 PM
ron-kim's Avatar
ron-kim
Thank's again for info , slot in seat hmmmmm,sounds like an easy thing to screw up?
Old Aug 22, 2011 | 06:28 PM
ron-kim's Avatar
ron-kim
Had been looking at the Simpson Platinum series but i'll check out RCI, thank's for your input/time.
Old Aug 22, 2011 | 11:27 PM
4DRUSH's Avatar
4DRUSH
Most aftermarket racing seats have that slot. Not saying you need it, just saying how it should be.
Old Jun 11, 2012 | 09:48 AM
jasonright's Avatar
jasonright
Hundreds of peoples are hurt or killed by lack of the required safety every year. When it comes to the harness you will use on the job, consider that several companies have set harness recommendations according to requirements that make sure the reliability of the harness.
To SAFETY:Harness Question
