Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
C5 Converter Size
Old Aug 22, 2011 | 09:17 PM
danielf's Avatar
danielf
Default C5 Converter Size
Just as a point of intrest , any c5 vettes running in the 11.50 range What size and type of stall converter are you running? Did you do any fine tuning to the tune set up once the stall was put in also?
Thanks dan
Old Aug 22, 2011 | 09:42 PM
Rob Petyo's Avatar
Rob Petyo
Thanks dan
Dan,
What gears are you running and what are your mods? If you are not modded, chances are a stall (only) is not going to put you in the 11.50 range.
You are going to need a tune after installing the stall converter, your tuner should be familiar with the process.
edit:
I just read your sig and you are already running 11.58, I think I may have mis-understood your question...
