Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Newbie questions.... very basic
Old May 5, 2002 | 03:50 PM
YO-EL's Avatar
YO-EL
Default Newbie questions.... very basic
Tire sizing.
My car is all 18".
Can I run 17" drag radials in the rear with 18" in the front, or do I need to stay with 18"?
Sidewall;
295/35/18 or 17 vs 275/40 or 45 18 or 17
And finally, after a few runs, should I
Turn on the A/C OR turn on the HEAT to cool down.
Thanks........
Old May 5, 2002 | 04:54 PM
Beach Bum's Avatar
Beach Bum
Default Re: Newbie questions.... very basic (indypace78)
Tire sizing.
My car is all 18".
Sidewall;
Thanks........
You can run different size rims on the back vs front, no problem.
I wouldn't turn on either.... just have your hood up whenever you're not racing or moving in the lanes.... the hood open is the best way to cool a motor.
good luck
Beach
Old May 5, 2002 | 11:49 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Ellis, in traffic, I usually turn the A/C on to cool down a few degrees, but at the track, you won't be driving long enough to do that. So parking and opening the hood is your best bet.
We all (at E-Town) use Pro Coolers to aid in our cool down. Better than a bag of ice since we won't get any water drip.
But you can use a bag of ice, just make sure you pull it off your intake before you run, yes, we've seen guys forget!
Old May 5, 2002 | 11:51 PM
YO-EL's Avatar
YO-EL
Default Re: Newbie questions.... very basic (Mr Mojo)
I'm in. Where do you get them at?
Old May 6, 2002 | 03:31 AM
pkmoose's Avatar
pkmoose
Cruise-In III Veteran
I usually turn my ac on until I am about ready to do a burn out, otherwise I will go to the line at around 210 degrees. It's very usefull if you have a long line in front of you.
Old May 6, 2002 | 08:55 AM
Mr Mojo's Avatar
Mr Mojo
You can get the Pro Cooler from www.lingenfelter.com
Old May 6, 2002 | 03:43 PM
mikeg826's Avatar
mikeg826
St. Jude Donor '06
How many runs in a row should you do? I did about 8 within a half hour on saturday? should i limit it to 4 and then sit out some time to let the engine cool down? :confused:
Old May 6, 2002 | 07:44 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Newbie questions.... very basic (mikeg826)
I like 40 to 60 minutes between runs.
Old May 6, 2002 | 08:32 PM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
Ellis, Saturday is not a true indicator of how quickly you will have to go back to racing. At a regular race day you will wait about 40 minutes between runs.
You can also get the procooler at the forum mall.
To keep the car cool, consider a lower temp stat, with Hypertech programmer to reset fans or custom tuning and a throttle body bypass mod.
You sigining up for the Corvette Challenge?
Old May 6, 2002 | 09:22 PM
mackeyred96
Default Re: Newbie questions.... very basic (REDGAR)
Ellis, You sigining up for the Corvette Challenge?
:yesnod: :yesnod: :yesnod: :yesnod: :yesnod:
Old May 6, 2002 | 09:36 PM
YO-EL's Avatar
YO-EL
Default Re: Newbie questions.... very basic (mackeyred96)
Yep, I'll be there 5/25.
I'll probably get some BFG DR's in the 275/40 size (deceided against the 315/35, wanted more sidewall), and a line lock. I actually like how my cars runs with the stock t-stat, steady 190.... See you there!
To Newbie questions.... very basic
