I took my car to the 1/4 mile for the first time since doing a few mods. Last time out at the track I had exhaust and a Superchips tune. I ran a 13.30.
Since then, I've added a Blackwing CAI, Vararam air bridge, ARH 1-7/8 inch LT's, 3 inch X-pipe with high flow cats, Borla Stingers, Yank 3800 stall, and 3.42 diff. Here's my new time slip.
I was extremely disappointed with my 60ft. I spun like crazy off the line, even when I babied it out under 2k. I was on 17 inch ET streets with 15psi in them. I don't think my tires are my problem, I believe it's my suspension. My stock suspension is as low as possible. Front bolts are removed, and rear bolts have 2 threads showing up top. So my question is, what kind of coilovers or shocks are the best for drag racing, but will still let me keep my car low?
Like in road racing/auto-x weight transfer is important. IF the car is too low then little or no weight transfer. Which means no traction under braking, acceleration, turning. Take it back to stock ride height and see if that helps. It is technically more complex than this but for all intents and purposes, I'm willing to bet stock ride height would help you more than just a bit.
Maybe I'm totally wrong on this but for what its worth that is my 2 cents.
IF the rear cannot squat under acceleration how do you expect to get traction?
If you go with the coilovers you will have to do 2 diff set ups on the car for sure. You will have to play with it for sure plus unhook your front sway bar. Your set is really bad some way on the 60ft for sure with the set up you are running.... You will get it just chg one thing at a time and just play with her.... Just remember it is like a woman will have to fine what she likes..... Robert
If this is all you have done to the car not that bad really with that slow of 60ft time. I see you are friends with Bret if you are close to him get him to look at the car and help you man. Bret is a great guy and know his stuff in these cars...... Robert
That 60ft is horrible. There have been Many cars with nearly identical setups cutting 1.5 60fts. And when I can feel and hear my tires spinning like crazy off the line, obviously a big adjustment needs to be made lol.
Yes... I already said that the reason I wasn't hooking was because of my car not having anymore travel in the stock suspension. My question is, what kind of shocks or preferably, coilovers will let me keep my car low, as well as still give me a good bit of travel?
Reading the post , I think with that setup you should be running faster and Suspension work is not really required. Do you have a Tuning program also a Drag pack will help out greatly and Finally Just plain seat time Getting used to the car is more important than add on's. In your coupe do you have ride selection?
15 PSI with M/T ET Streets too much? I would think 11-12 PSI.
Depends on track prep and power level. Back in the day running 10-12psi (I've even seen as low as 9 1/2 ) wasn't unheard of in a manual C5 but with the wide array of better clutches out today and the smarter launch techniques perfected by the well known late model Corvette stick drivers out there I don't think 15 is too high anymore, especially with a 17" ET Street and an automatic trans.
I'd even consider going a little higher in pressure or even to a drag radial.
From: 10.70 @ 124mph, Stock Bottom End @ 3620lbs, ECS Racing Team Member. The 1st NMCA LSX Index Rumble World Champion. 2011,12,13 Champion
*I run 19 to 19.5 in MT Drag Radials. I have gone 10.70's without any issues.
*I suggest stock ride height.
Remove front sway bar.
*At you ET I would not suggest coil overs, adjustable shocks........ I am using the original shocks (35,000 miles 98 model). I removed my sway bar. I do drive my car on the street. I do notice a difference but for me it is not that bad. I know some other people that have noticed a huge difference driving on the street w/o the sway bar.
*Take baby steps, make one change at a time, this way you will see if you are going in the right direction.
Track conditions play a huge part in this. Was it humid? This will cause the track to go away.
Your MPH is not far off the ET. Normally with wheel spin you will see a strange numbers.
At stock ride height I have so much wheel gap it's sickening. That's why I was looking for a product recommendation. I ran the ETs at 15psi because that's what I read was appropriate for my car's weight on the Mickey Thompson website. I'll try removing the front sway bar, but I'm extremely hesitant about raising the car back up.
As for the track conditions, it was in the low 70s and seemed pretty dry.
From: Still the Fastest (still running) Stock Bottom End Blown LS1/ 2010 ECS CC 10.50 CHAMP Hamilton, NJ
Originally Posted by LS1LT1
That's a fine lookin' ride.
I have removed my front sway bar, but never saw a difference, other than being very uncomfortable around turn with the front skinnies on. I put it back in, and then cut my best 60's with it in.
The 60ft here may not be that bad with how you have the car set up at the time... Alot of the guys in here dont tell you what all is in the car and how it is set up. But lowered to the ground with the bolts is not good for the 1/4 mile as you know... Robert
Thanks for the kind words guys. I may go after a drag pack here soon. My goal is to run 11s with bolt ons. I think with a little more traction and a good dyno tune it's completely possible.
