On the last pass of the season in the 10.50 index against Dave my car didnt run the number. It only went a 10.67 so I knew something was wrong. About a month ago I pulled on all the valve springs to make sure I didnt break a spring. Set the lash again and fired it up. It was making a slight knocking. Oil pressure was solid and good as always. I pulled the manifold to check for bad lifter and all looked good so out came the motor today. Crank and rod will be at machine shop this week.
SAVE your $$$ just get some "ZAINO" & it will run as good as new...I was gonna do a cam etc to run 11.50 this yr. but just tore down the engine and Zaino'd it & I should be good to go...
From: Still the Fastest (still running) Stock Bottom End Blown LS1/ 2010 ECS CC 10.50 CHAMP Hamilton, NJ
I think I'm happy to see you got the prob worked out. Maybe the machine shop can get it back fairly quick.. Good luck, and congrats again on last season..
The shop knows I need it very soon so it wont be a problem. Jeremy from Extreme race engines does my machine work. He builds killer motors in case anybody needs motor work.
I found my problem also. Too bad divorce is so damn expensive.
cheaper to keep em and be miserable is not a racers best option. now you can race anytime you like. dont make the same mistake twice like i did. unless your a glutton for punishment.
Yea. if sheep could only cook we wouldnt need women!! LMAO!!!
