Going to run my GS A6 at the street drags at Willow Springs tonight.
What is the best way to shift the A6? In the past I turn off traction control and just leave it in drive, but I am told that causes 2nd gear starts.
I read 0n another board that in order to leave in 1st with traction control off, you have to put it into S mode and paddle it into 1st. The only time I have tried that on the street with TC on, it went into the rev limiter as soon as I mashed it. Don't like doing that.
If I managed to leave in 1st and paddle it into 2nd, will it shift the rest of the gears automatically even if it is in S mode?
No that's not true, the only way it leaves in 2nd gear is if you make it do that, either by putting it in 'S' mode and then paddling it down to 2nd or when driving around 'S' mode and activating the paddles (simply by touching them) and then come to a dead stop without doing anything. It will then downshift all on it's own as you slow down but stop only at 2nd gear and not 1st (unless you paddle it to 1st manually).
Some people have various preferences when it comes to this but what I've been doing for many years now is turn off traction control, put it into 'S' mode and that's it, don't touch the paddles during the pass at all.
I personally do use the paddles during the burnout and once again at the top of the track to hold 3rd gear but please don't focus on any of that at this point because it will only confuse you and likely lead to some mistakes.
