Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
325 BFG DR problem
Old May 26, 2002 | 12:25 PM
hookedup's Avatar
hookedup
Default 325 BFG DR problem
JP, Mackey or anybody else help!
I just mounted up my new BFG DRs, 325/50/15s on Weld Draglites 15X10, 7.5 BS, 5/16 spacer on my '92 with stock rear spring & HAL shocks. Took it out to go to the track and found that they rub BAD at the top of the wheel well flare :eek: Looked like I was doing a burnout every time I nailed it! Tightened up the shocks all the way to 12 from 5 and it still happened, took all the extra tools & weight out, still no help. I only weight 185, so it's not a fat a** causing this, any ideas?
Has anyone raised their C4 in back by using shorter spring bolts? Anyone know if the 6spd. spring has a higher deflection rate or ride height and did you swap that spring in with the D-44?
Need to correct this nightmare so I can race before I go into withdrawl, I hate being a spectator!
Thanks Dave :confused:
Old May 26, 2002 | 12:31 PM
The Green Rocket's Avatar
The Green Rocket
Default Re: 325 BFG DR problem (new92racer)
Is it the outside edge of the tire that is rubbing? If so, can you remove the 5/16" spacer and not rub anything on the inside?
Thomas
Old May 26, 2002 | 02:06 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Try raising the back of the car up about 1/2 inch. It should be OK.
Old May 26, 2002 | 08:09 PM
hookedup's Avatar
hookedup
Default Re: 325 BFG DR problem (mackeyred96)
Mackey,
I must have been reading your mind. I went up to the hardware store and bought two 1/2X8" bolts, replacing the original spring mounting bolts with these raised the rear approx. 1" and cured the problem.
BTW Green Pocket, I tried to remove the spacers, no dice, the wheels still hit the caliper even after more grinding. I know I might be able to grind them down even more and make them fit for now, but with new brake pads I'd be in trouble again.
Let's go racin'!
Dave :D
[Modified by new92racer, 7:14 PM 5/26/2002]
Old May 26, 2002 | 08:36 PM
mackeyred96
You'll never fit without the spacers + you may hit the inner frame rail.
I will be looking to go to the smaller brakes.
Old May 27, 2002 | 09:08 AM
hookedup's Avatar
hookedup
Mackey,
I was at an IHRA event recently and found a C4 Super Stocker in the pits with "Aerospace Engineering " brakes on the front. They looked really well built & light too! I'll check with them, maybe they build the rears to match.
Dave :yesnod:
Old May 27, 2002 | 10:26 AM
mackeyred96
Mackey,
Dave :yesnod:
I'm looking to change the fronts also.
Do you remember who the racer was??????
Class, car Number anything?????
I'd like to talk to him.
Old May 27, 2002 | 11:48 AM
ralph's Avatar
ralph
I had the same problem with them rubbing the fender. two things i did to correct it. First raise the rear; you can get bolts from MAD with more thread area so you can adjust the rear in either direction ($30 with poly bushings). I raised mine about 1 1/2" as the clearance was only about 1 inch when i started with the taller tire. If you raise the rear enough, it will not squat as much on launch, but you'll still have potenital for rubbing the fenders when you hit dips in the road. To stop this, i also added long rubber stoppers in place of the stock ones. The stock stoppers are about 1 1/2", and the ones i've added are conical shaped and about 2 1/2 to 3" long. I also wired back the inner rear of the fender well to stop them from rubbing. Problems solved
Old May 27, 2002 | 10:21 PM
hookedup's Avatar
hookedup
Default Re: 325 BFG DR problem (ralph)
Mackey,
I think I wrote down the guys name with the C4 SS car somewhere, but I can't lay my hands on it right now, but I'll keep looking for it. Phil (wheelsup) & I were in Petersburg at the national event race last month when we saw the car, spent a hour crawling all over the thing. It's a white coupe, no lettering, father-son team, something like a SS/PSA with lotsa' neat tricks, and it went 9.4-9.6s on 10.5" tires!
Ralph,
The tall rubber stoppers you used sound like a great idea for when I loosen the shocks for the drive home, where did you get them? I guess old traction bar snubbers would work, if I can still find them! I'd better check on that inner fender panel on this car, I've already taken them out of the '89.
BTW guys, what's a good starting air pressure for these monsters?
Thanks for the tips guys, if I find out anymore info I'll update ya.
Dave :cheers:
[Modified by new92racer, 9:25 PM 5/27/2002]
Old May 28, 2002 | 12:23 PM
ralph's Avatar
ralph
I got thew stoppers at CarQuest, but you are right, they look just like the old traction bar stoppers. I've been running them with 18-20 lbs of air, but they might need a little more, cause i've noticed that they are wearing more at the edge than the center. Traction has been great. And you dont have to heat them much on a warm track, but smoke'm good when its cool out.
Old May 28, 2002 | 04:12 PM
mackeyred96
I don't thik my next set of tires will be radials????????????????
Old May 28, 2002 | 04:25 PM
ralph's Avatar
ralph
And the reason being???????????????
Old May 28, 2002 | 04:56 PM
J Z06's Avatar
J Z06
:confused:
ralph....
I think He's hell bent on 4.30 or steeper gears and tall slicks.
Old May 28, 2002 | 05:08 PM
mackeyred96
I know what my car will do with the 325 BFGs, so it time to try something else. Maybe a set of Hoosier stocker tires ;)
Old May 28, 2002 | 05:54 PM
ralph's Avatar
ralph
ok.....i asked cause mine seem to be working very well. I wish i could say the same about the driver :mad
Old May 28, 2002 | 06:10 PM
mackeyred96
You've been hanging around Panuzzo to long. ;)
Old May 28, 2002 | 08:56 PM
ralph's Avatar
ralph
That could be it!!!!!!!!!!!!!!!
To 325 BFG DR problem
Old May 29, 2002 | 12:21 AM
hookedup's Avatar
hookedup
I've got a set of 12.5/28/15 MT ET Streets for the '89 when it's ready, but just in case, I could use them on the '92.
I've been giving the 'taller tire+more gear' a lot of thought, but that will come around with the solid roller. Know of anyone running a C4 with 30" tires now without tubbing? 4:56s?
:yesnod:
Old May 29, 2002 | 11:26 AM
mackeyred96
Me very soon. ;)
Old May 29, 2002 | 10:26 PM
hookedup's Avatar
hookedup
:cool: :cool: :cool:
Take lotsa pictures for us! :yesnod:
