Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
1/4 mile suggestions/HELP
Old Sep 19, 2012 | 07:43 PM
Neez's Avatar
Neez
Default 1/4 mile suggestions/HELP
Hey guys, first off i will tell you my setup.
Currently im running an 01 Z06,
Engine Mods: Stock 347, prc 227's, ms4 cam, lg super pro's, B&B Bullets
Suspension: Stock
Tires: Mickey Thompson ET street Bias ply's 26x11.5x16
Drivetrain: Everything stock (stock clutch, 3.42's, tranny etc)
Now, Ive ran this car probably a total of 30 passes give or take, with a personal best of 11.69 @ 121, with a 1.706 60ft. (Elevation 1600ft, 34*C)
Its very consistent with trapping 120-121, and 60 fts are fairly consistent as well 1.7xx most of the time, i do realize im still learning the whole launch and clutch situation, but as per 60 ft's how do you feel that those times look.
Ive been debating with changing the rear end ratio to either a 3.90 or 4.10, as my car is more so top end power.
Im basically looking for a little input from the 1/4 mile guys, who know their corvettes and their drag racing, id like to run faster and that i know i will when i finally get my fast92/92 setup installed.
Old Sep 20, 2012 | 12:47 AM
4DRUSH's Avatar
4DRUSH
Sounds like you're doing great for small amount of passes.
Things are a little slow around here, plus the six speed racing stuff mostly gets discussed in the C5 Performance Section.
http://forums.corvetteforum.com/perf.../?daysprune=-1
Old Sep 20, 2012 | 01:47 AM
jpee's Avatar
jpee
I'll pipe in here with the "little" that I've learned in racing since 1964 Yup I'm "THAT OLD"
First remember these two things...with regard to your ET & MPH
#1 more Horsepower will give you more "SPEED or MPH" But it may also cause you to run a slower ET "TIME" because of wheel spin on the launch..
#2 Chassis set up "correctly" WILL get you a quicker or lower ET but will NOT make you go faster (MPH) With HP increase you should get a higher MPH.. I'll give you my car as an example...
I have an 05 (A4) when I bought it "Bone Stock" it ran 12.97 @ 109 mph
So I added Drag radials, & I went 12.8x but my MPH was the same 109.22 because I was not making mote HP .. I was just putting the HP I had to the TRACK
So now I want a better ET.. I got a CAI (Vararam) KOOKS Headers, & a "TUNE"...
Well the car responded by running 12.45 @ 112 mph... I still wanted more MPH & better ET ...
I got a Hi Stall converter this week & tonight at E Town I ran 11.75 @ 117 MPH
I emptied the piggy bank, so will have to wait until after the Christmas holidays for my Cam & Heads.. that should get me into the low 11s (I HOPE)
Old Sep 20, 2012 | 04:10 AM
LS1LT1's Avatar
LS1LT1
Not bad John, not bad at all.
That's a solid 11.6x at 118+ in November/December.
Not to totally hijack Neez's thread LOL but what were your sixty foots like?
Old Sep 20, 2012 | 05:42 AM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
Suspension: Stock
I believe you're using the proper tires for your set up. And, with more seat time, you're 60' will come down.
That said, these 6 speed cars love big gearing. Go with a 4.10 built diff, and you'll see what I mean. Crazy fun on the street and the track numbers will be what you're looking for. You MPH will increase and your ETs will drop. You'll be right in the peak of your HP when crossing the traps, instead of 1000 rpm below it.
For street cruising you'll likely be at about 2100 RPM at 75 mph.
Old Sep 20, 2012 | 09:14 AM
jpee's Avatar
jpee
Marc.. my 60' (3 of them) were 1.65 1.66 @ 1.69 the 1.69 I left at 1000 rpm, I have to stall it to 1500 - 1700 for best results.. & I got lucky the Nitto 555 will hold (I have to do a little more burn out)...
Old Sep 20, 2012 | 02:18 PM
LS1LT1's Avatar
LS1LT1
Old Sep 20, 2012 | 05:35 PM
Neez's Avatar
Neez
This was kind of what i was looking for. I have heard of guys running 3.73, 3.90, and 4.10 gearing. for myself, we dont have any road courses around here, so the only spirited cornering it gets is cloverleafs, and highway corners and a couple of "closed" roads in the city that are dead a liittle later at night, but it seems as though the stock 3.42 gears are just too long. With peak power being made from 4500-7000 it seems that its just not quite enough gear to keep it in that powerband. That being said, i was really debating on what gear ratio to go with. the 4.10's do definitely sound like the best option.
As per MPH goes, trapping 120-121 all day, ive definitely got the power to run quicker and yes, its going to take some seat time. The clutch may also be hurting me a little bit on the 60 ft's, as the car has 100,000kms on it, and its still on the same clutch that it had when i bought it.(not sure if its after market, or stock)
Old Sep 21, 2012 | 11:36 AM
MikeV's Avatar
MikeV
You didn't mention your air intake? If you don't have a REAL cold air intake that should give you at least 2 tenths and 2 MPH.
Mike V
Old Sep 21, 2012 | 01:47 PM
Neez's Avatar
Neez
Mike V
I had a ****** RM racing twinflow setup (came with the car), we pulled the twin flow off on the dyno after we got it tuned, and just used a k&n intake style filter mounted onto the end of the maf, pulled 19rwhp and 16ftlbs more on a dyno dynamics dyno, so i guess you could call it somewhat of a custom intake, or as ive been told befor a "hackjob" but i dont care what guys want to call it, it was a proven 19rwhp, weather it was a gain or just restriction with the old intake.
Old Sep 21, 2012 | 06:43 PM
MikeV's Avatar
MikeV
Thats still taking in HOT air from the engine compartment. Get a Vararam and you won't be sorry. Cheapest 2 tenths you can buy!
Mike V
Old Oct 1, 2012 | 05:41 PM
Neez's Avatar
Neez
well, i didnt change anything to the car, and managed to get the "ol boot" on the weekend running 11.46 @ 119.91mph. practiced launching, and ended up being able to cut a 1.587 60ft time. Im quite pleased now that i can finally launch my car, and manage to bang the gears as well as i did. Im hoping to lower those times a little closer to the 10's with a set of 4.10 gears in replace of the 3.42's. And who knows, guess wait and see what kind of power gains i get out of my fast 92/92 setup with 100mm maf
To 1/4 mile suggestions/HELP
