Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Wheel studs
Old Jun 13, 2002 | 09:30 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Wheel studs
Has anyone install these type of threaded wheel studs on their C4????????
5/8'' Wheel Stud Kit: Larger shank diameter provides additional metal to metal contact with the steel for reduced stud flex and increases strength. Complete with flat type lug nuts and stud spacers to fit various thicknesses of disc brake hats. Drag race use only. 5/pkg.
710-46140 5/8''-18 x 4-13/32'', Screw-In Stud | $ 41.99
Click on link for photo.
http://www.jegs.com/cgi-bin/ncommerc...rnbr=710-46140
Old Jun 13, 2002 | 09:36 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: Wheel studs (mackeyred96)
I was looking at these.
http://www.lingenfelter.com/lingenfe...=14&pf%5Fid=34
Old Jun 13, 2002 | 09:39 PM
mackeyred96
Default Re: Wheel studs (Mr Mojo)
Thats what I have now and they arn't long enough.
Old Jun 13, 2002 | 10:39 PM
Mr Mojo's Avatar
Mr Mojo
Says not to use those longer studs with spacers. Thoughts?
Old Jun 14, 2002 | 08:55 AM
DeenHylton's Avatar
DeenHylton
Your axle flanges will need to be drilled and THREADED to accept the 5/8 studs. Deen
Old Jun 14, 2002 | 02:40 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
This product is not legal for sale or use on California pollution controlled motor vehicles.
WTF??? :crazy:
Old Jun 14, 2002 | 09:40 PM
mackeyred96
Default Re: Wheel studs (DeenHylton)
Deen, I know I had these on my Super Stock Chevelle but I'm wondering If anyone has done it on a C4 and what if any problems they had.
Old Jun 14, 2002 | 10:12 PM
wheelsup's Avatar
wheelsup
John, I use the 5/8" studs with the Strange axles. Would 1/2" studs work as well. Seems to me you would need to make sure that there was clearance on the inside of the hub.
5/8" studs are HUGE. :eek: ....But :cool:
Phil
[Modified by wheelsup, 8:14 PM 6/14/2002]
Old Jun 14, 2002 | 10:21 PM
mackeyred96
Default Re: Wheel studs (wheelsup)
Thanks Phil, 1/2 would be OK.
I'm more looking for the type of screw in stud more than size.
Old Jun 15, 2002 | 08:22 AM
DeenHylton's Avatar
DeenHylton
Most axle flanges are hardened and will require special tooling to drill and thread. On the 5/8" stud the stud fills the hole that's drilled in your wheel leaving no room for error when drilling the axle ( on a 5/16" or 1/2" stud the shank of the lug nut fills the wheel hole on an aluminum wheel). Unless your running big slicks like 31" X 12"wide or something similar you shouldn't have to go to the 5/8 stud. I also ran 5/8 studs in my Ford (514 cu. in. 700 HP 9.50's ET) that was after I sheared two sets of 1/2" studs off in a two month period. :eek:
P.S. I haven't done this to a Corvette so I'm just ASSUMING it would work if you sent your axles out to have the work done...you know what they say about those that assume :lol:
Old Jun 16, 2002 | 04:54 PM
mackeyred96
Thanks to everyone :)
Old Jun 22, 2002 | 06:26 AM
MJ's Avatar
MJ
John,
Are you looking for a longer stud, or, do you want the larger diameter. If you are looking for a longer stud try the GM performance part. I run this stud with a 13 mm spacer behind a Weld Dragstar, through a Weld open ended lug nut and get a full 12 mm of extension past the nut. Let me know and I'll post the part number.(it's at my office)
Aloha,
Mike Renfro
Honolulu, Hawaii
Old Jun 22, 2002 | 08:07 AM
mackeyred96
Default Re: Wheel studs (MJ)
Mike, long term I want to go to the thicker studs but for now a longer one would be find. The Moroso ones I have now are long but maybe your would be better.
Yes, PN please.
Old Jun 23, 2002 | 05:20 AM
MJ's Avatar
MJ
They are GM part number 22551491. They are a total of 3 5/8th inches long.
Mike
To Wheel studs
