Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
c3 drive shaft help
Old 04-28-2014, 12:51 PM
RacerX79
RacerX79's Avatar
Default c3 drive shaft help
Hi, I am looking to install a stronger drive shaft in my 79, It will see some street and track. I will be putting down around 1000 hp in the future and want to do it once, what are my options for a stronger drive shaft and a loop in the stock tunnel?
Thanks for replies.
Old 04-28-2014, 09:06 PM
Vettekid1992
Vettekid1992's Avatar
Thanks for replies.
is it a stick or automatic? you an put a 3" driveshaft in that tunnel but its a very tight fit. i run a stock steel 2.5" driveshaft in mine with solid u-joints. car has been 9.50's in the 1/4 and over 117mph to the 1/8th with no problems on a powerglide 1.4x 60's. i also have a loop
Old 04-29-2014, 10:56 AM
RacerX79
RacerX79's Avatar
Thanks for the reply & pics. I was considering attempting a 2.75" thick wall driveshaft but don't know how well a driveshaft loop will fit.
I like your crossmember mod for the exhaust. What mufflers are those you are running?
Your exhaust is tucked up there nicely.
Old 04-29-2014, 11:44 AM
Vettekid1992
Its a full Custom ARH exhaust system. The driveshaft loop is extremely tight to the driveshaft right now.
Old 07-10-2014, 11:45 PM
tektrans
tektrans's Avatar
I stuffed a 3" chromoly one in my 78 and its tight. I am going to have to beat on the tunnel a bit to get a loop in there but it'll work.
cant beleive you are running the stock unit Vettekid. Wish I knew it would hold up like yours is before I put the 3" in.
To c3 drive shaft help
Quick Reply: c3 drive shaft help
