Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
C4 drivetrain
Old Jul 24, 2002 | 12:21 AM
kawboy5792's Avatar
kawboy5792
Default C4 drivetrain
what kind of horsepower and torque can be safely put through a 94 ZF6 drivetrain? im thinking of a stroker with juice, but im wondering if the tranny or rear end will take it? thanks guys..... :cheers:
Old Jul 24, 2002 | 12:36 PM
Bravery's Avatar
Bravery
Default Re: C4 drivetrain (kawboy5792)
The transmission can handle alot, the rearend is a Dana 44 and can handle plenty, but your clutch, tires, halfshafts, driveshaft and suspension are a different story. :-) In my guesstimation, I would have to say the stock setup can hold an 11 second car, but once you get LOW 11's, be prepared for something to give....
Mike
Old Jul 24, 2002 | 02:25 PM
J Z06's Avatar
J Z06
Default Re: C4 drivetrain (Bravery)
Rich S has put some power through His GS-ZF6 and D44. He just re-did the 44 and drives it HARD with DR's at the strip. He's making gobs of power too(over 360RW). Seems to be holding up fine for Him.
Old Jul 24, 2002 | 05:55 PM
Red Rocket's Avatar
Red Rocket
My 350 was at 360RWHP/360Torque and held up with three years of drag racing, ET streets and 4000 RPM clutch dumps. Would recommend beefed up ujoints and spindles. My 396 is close to 400RWHP/420Torque and would be over the edge with ET streets and 4000 RPM clutch dumps.
Old Jul 24, 2002 | 06:17 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
With good parts they'll last longer than you would think.
Old Aug 3, 2002 | 03:45 PM
KyleBst264's Avatar
KyleBst264
If I were in your position, I'd replace the halfshafts and U-Joints. The halfshafts are something that you should watch out for. Those things will do some damage if they break. If you're not gonna replace them, atleast draw lines on them with a magic marker or something. Then you'll be able to monitor if they're twisting or not.
Old Aug 3, 2002 | 08:16 PM
vetterestorer's Avatar
vetterestorer
The ZF can take it the clutch can't, go with a centerforce. The 44 can also take it, but change the half shafts and drive shaft. add a set of drag radials and your good to go. Just look at the sledgehammer 880 hp. I run a big block C4 with gobs of power and no problem. Also a good set of strong wheels (ever see a wheel rip apart??)
To C4 drivetrain
