Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Paging Mackey
Old Aug 15, 2002 | 02:36 AM
Half Fast's Avatar
Half Fast
Default Paging Mackey
Are you running the stock fuel pump or did you go to a higher volume pump?
The reason I ask is on the dyno my car is making the power in the upper rpm's but at the track it's not getting the mph that you would expect with the et's it's running. The 60' time was great for street tires (1.82) and the 1/8th et and mph look right. At the end of the 1/4 it seems to be down about 3-5 mph from what I would expect with the et's it's running?
I've got the 30lb injectors, new fuel filter etc. and am wondering if the extra load from aero resistance etc. at the track is needing more fuel than the pump can deliver. I know that what the motor is pushing is putting me pretty close to the edge for the stock pump. Any thoughts since we are both at about the same RWHP?
Thanks,
Old Aug 15, 2002 | 07:23 AM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Paging Mackey (Half Fast)
I'm still running the stock fuel pump without any problems.
I also use the 30# INJECTORS.
Old Aug 15, 2002 | 06:49 PM
Half Fast's Avatar
Half Fast
Default Re: Paging Mackey (mackeyred96)
First time at the track, temps were low 90's, typical Fl humidity. Ran a 12.701 @ 105.86, 1.82 60', 8.15 @ 86 mph 1/8. It seems to be pulling good through the 1/8. Nothing noticeable in the car at the top end of the 1/4, no miss, no knock. I'm trying to sort it out and all I can think of is that the fuel pump is not keeping up with it on the big end. What fuel pressure are you running?
Old Aug 15, 2002 | 07:16 PM
mackeyred96
You must ask Julio at Cartek for that info. I have no idea. :confused:
To Paging Mackey
