Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Ride height
Old Oct 1, 2015 | 09:20 PM
1BAD97VETTE's Avatar
1BAD97VETTE
Default Ride height
Just currious to what you guys ride height is on your drag setup!
Im running QA1's all four corners, LG Rear spindles....
Im sitting at about 28.5' rear and 26.5" front
Old Oct 5, 2015 | 12:48 PM
Ksths2's Avatar
Ksths2
28.5 and 26.5" measuring from ground to what?
Old Oct 5, 2015 | 01:26 PM
1BAD97VETTE
ground straight up to bottom of fender or quarter panel wheel well opening!
Old Oct 5, 2015 | 05:03 PM
Ksths2's Avatar
Ksths2
ok I figured that but I better ask
I'll look tonight. I'm running QA1's as well but stock spindles, w/ fronts a 26" tall tire on a 17" rim and rear 28" tall QTP on a 16" rim
Old Oct 6, 2015 | 01:43 AM
HOXXOH's Avatar
HOXXOH
26.5 front and 26 rear.
Of course, that's before the launch.
With F55 suspension the rear hardly squats, but the front instantly goes to the full limit of shock extension before lifting the tires and doesn't settle down completely until around the 1/8 mile mark.
Old Oct 6, 2015 | 09:34 AM
1BAD97VETTE
what size rear tire are you running....
Im thinking about bringing my height way down and seeing how it does, It seems to do better when I have the qa1's pretty soft on rear sitting that high, I may bring the height down a few inches if it will clear the 28's and run the qa1's stiffer!
what 60's are you guys getting
Old Oct 6, 2015 | 09:35 AM
1BAD97VETTE
thanks and sounds good! what settings do your run your qa1's!
Old Nov 18, 2015 | 08:29 PM
lsxvette's Avatar
lsxvette
subscribed
Old Dec 2, 2015 | 08:58 AM
Gxpz06's Avatar
Gxpz06
25.5"
Old Dec 2, 2015 | 09:57 PM
HOXXOH's Avatar
HOXXOH
I'm on 275/40 x 17 Hoosiers and 26/4.5 x 17 M&H
1.48-1.50 60'
It's only a LS3 bolton A6
To Ride height
