Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Beginners Question?
Old Aug 26, 2002 | 11:04 PM
zipity's Avatar
zipity
St. Jude Donor '10
Default Beginners Question?
I just returned from Carlisle with newly added intake and exhaust work completed. I am planning on running 1/4 mile at Atco Raceway and need some advice. The car is a 98 Convertible, automatic trans, no adjustable suspension, and stock run flats. I am planning on running in gear selector 3 (overdrive off). What about the traction control, on or off? What tire pressure should I have the EMT tires at? Any other advise for a first time dragster?
:chevy
Old Aug 26, 2002 | 11:13 PM
StuzVette's Avatar
StuzVette
Cherish your Hopes...
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07
Default Re: Beginners Question? (zipity)
Allow me to be the 1st to Welcome you Zipity :seeya
automatic no overdrive and no traction control are a good combination :yesnod:
Run flats should carry high tire pressure to avoid hopping.
Dont try to burnout on the lauch
oh go real fast! :lol:
Old Aug 27, 2002 | 03:29 PM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
Welcome to the forum zipity.
I have a 99 auto.
I have had some success lowering the tire pressure on the EMT to about 25 psi.
Traction control off, AC off.
At Atco you don't have a choice but to go through the water box. Try NOT to get water on the tires. With stock tires you do NOT want water. Stop just after the water in the burnout box. When signaled out, do a samll burnout to through off the water and get a little heat in the tires.
Car should be in 3 (drive) not because it is faster but because if you bracket race, you want it to be there.
Stage the car and you can either leave from idle or hold the brake and raise rpm to about 1000 rpm. experiment a little.
Third yellow comes down, let it rip. Go easy first time to get a feel for the car and the track. The exit is on the right.
Have fun.
Also, consider coming up to Englishtown for the Corvette Challenge on Saturday. Lot's of Corvettes and lots of free advice.
Click on link in my sig if you are interested
Old Aug 28, 2002 | 08:06 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Welcome to the forum, zipity :)
To Beginners Question?
