Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
My first ever automatic, Help me launch this L98...
Old Aug 27, 2002 | 03:42 AM
BioRxOkc@aol.com's Avatar
BioRxOkc@aol.com
Default My first ever automatic, Help me launch this L98...
I have an 89 convertible, pretty stock ~270hp at the crank, a 700R4 with stock TC and a 2.59. It's pretty respectable, but I am curious on the best way to launch this set up for good 60' times. Do I need to powerbrake and if so what rpm do I set at before I take off. Also, what is the best way (outside of major engine mods) to get the 60' mrk down? I have seen many L98's in the high 1 second mark. Can I get there without too much cost?
Old Aug 27, 2002 | 10:10 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: My first ever automatic, Help me launch this L98... (BioRxOkc@aol.com)
I just started racing this year with an automatic. With the stock torque converter and 2.59 gears, I would just punch it from idle and go.
Now that I have a high stall TC and 3.45 gears, I bring it up to about 1200 rpm and hit it.
With the 2.59 gears I had a best of 1.95 60' time.(LT1)
Old Aug 28, 2002 | 03:13 AM
TA's Avatar
TA
I have the same motor, trans, and rear that you have and judging by your hp, I have very similar mods to you. Before purchasing drag radials the best '60 time I could put down was 2.01, but they averaged about 2.1x. I have only been to the track once since putting the drag radials on and I made three runs and all three were 1.95s. I achieved this by power braking to about 1200 RPM and then nailing it on the last yellow. I did heat the tires up pretty good with decent burnouts on all three runs and ran about 20 lbs. in the tires. Hope this helps. :cheers:
Old Sep 1, 2002 | 10:24 PM
KyleBst264's Avatar
KyleBst264
I have an 85' with an L98, and I power brake it, get the RPM's up to 1700, and on the last yellow I let it rip. I usually have 1.90 sixty foot times. Today I had a 1.88
Old Sep 1, 2002 | 11:57 PM
MrNuke's Avatar
MrNuke
Default Re: My first ever automatic, Help me launch this L98... (KyleBst264)
At the CCC on Saturday in Etown, what best seemed to work for me was to launch around 1200rpm and floor on the last yellow. Got 1.889 60' with that. If I powerbrake to 2000, I get wheelspin and 2.0x 60' times, but higher trap speeds at the end of the 1/4.. I too have an '85 L98 but with the intake work, I'm down a bit on off-the-line tourque I think..
I'll be playing with launching techniques at LVD in Oct.. :cheers:
To My first ever automatic, Help me launch this L98...
