26" or 28" Tires with 3.42 gears
My car is a 2002 A4, just trying to find the best combo for the 1/4 mile. Would the 26" tires bring more gear out in the rpms than the 28''s. Thoughts
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
I vote 26".
There are lots of threads discussing this topic.
As the other poster mentioned, unless you're pushing 800+, the 26" would be the best choice.
Understand, concerns about tire growth depend upon the type of tire you run.
I run 3.73 gears and an A4 with a 3600 stall converter but even so I prefer the 26 inch tall tires. It lowers the effective final drive a little. I never get out of 3rd gear with an A4 so, from a gear ratio standpoint why run 28 inch tires?
I feel that because we are limited as to tire diameter compared to the 33 inch tires other cars often run that for us when it comes to tire patch and grip wider works better than taller.
I hope this information helps you make the right decision for your car.
Received 1,762 Likes
